Old 11/16/10, 4:17 PM
Default 5/8 deck bolts
Does anyone have a copy or can cite from CABO when deck bolts were required. I know I was installing them in the 80's......thanks.
Jeff
Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/16/10, 7:02 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Re: 5/8 deck bolts
Jeff,
This might help www.decks.com
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Old 11/16/10, 7:21 PM
Robert Ernst Robert Ernst is online now
Here is another good site. http://www.thedeckbarn.com/howto-buildadeck.aspx
Old 11/16/10, 9:59 PM
I appreciate the response guys but I know how to build decks..... I am looking for an old BOCA reference....... once the ICC took over in 2000 I threw my BOCA NC residential book away and I wanted to reference same to my client whose seller is stating that they were not required at the time the home was built. I spoke with one of the AHJ whom I have worked with over the last 15 years......he said it was in there but he too no longer has his BOCA book but validated that it has been required for at least 15 years.....at least in my county.
thanks
Jeff
Old 11/17/10, 11:33 AM
Jeff,
I would say that you are correct, they have been around a long time. What do you think of the 1/4 inch diameter structural wood screw that is suitable for deck ledger?
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 11/17/10, 5:06 PM
Depends on the shear strength and the number of screws used.
Many fasteners are made overseas where the heat treatment differs from here in the US
Old 11/17/10, 5:34 PM
GRK http://www.grkfasteners.com/en/RSS_1_2_information.htm
http://www.grkfasteners.com/index.asp
Made in Canada
Old 11/17/10, 6:10 PM
Old 11/17/10, 7:06 PM
Christopher Currins's Avatar
These are allowed by local AHJ.
5-8-deck-bolts-hpim7833.jpg   5-8-deck-bolts-hpim7839.jpg   5-8-deck-bolts-hpim7850.jpg
Christopher Currins
Certified, Licensed
Old 11/17/10, 7:21 PM
Pretty lienient code enforcement in your area huh!
Old 11/17/10, 7:27 PM
Apparently in this particular town. I did get them to add more, they were at minimum 48" center. It was only a $400,000 house, new construction, what do you expect.
Christopher Currins
Certified, Licensed
Old 11/17/10, 7:29 PM
Old 11/17/10, 7:38 PM
They didn't like "wasting" fasteners for hangers at joist either, pic. 3.
5-8-deck-bolts-hpim7827.jpg   5-8-deck-bolts-hpim7828.jpg   5-8-deck-bolts-hpim7831.jpg   5-8-deck-bolts-hpim7834.jpg
Christopher Currins
Certified, Licensed
Old 11/17/10, 7:57 PM
It sure makes me wonder on where they learned to build things.
Old 12/10/10, 7:34 PM
Robert Manley Robert Manley is offline
I do not see the bolts staggered 16" o.c. every other on the ledger either in picture 4. I am wrong. Look at picture 4 I see a pattern far right then nothing for well over 24" inches. Not just the type but appears not even close to enough..
Robert Manley
7 County Home Inspection, LLC
612-919-3844
www.7countyhomeinspection.com
Thermal Infrared Certified
Lag bolts used as through bolts on a deck rnapper Exterior Inspections 6 3/31/10 11:07 PM
Using the Prescriptive Residential Deck Construction Guide mcyr Exterior Inspections 0 7/21/09 7:10 PM
Check The Deck wdevries Canadian Inspectors 1 7/9/08 2:00 PM
Another deck Collapse rcooke Canadian Inspectors 11 3/30/08 8:03 AM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
