Old 6/12/07, 2:51 PM
Craig C. Owen Craig C. Owen is offline
Default Adding plumbing in existing concrete floor
Brand new house, in the building process. Concrete basement floor has been poured. Builder forgot to add plumbing for wet bar. Drilled holes in the slab to add plumbing. Any problems with this? Not a post tension slab.
Old 6/12/07, 4:48 PM
Jeffrey R. Pope's Avatar
Default Re: Adding plumbing in existing concrete floor
Then there should be no issues, except (perhaps) moisture intrusion. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/12/07, 4:49 PM
afrost afrost is offline
Please Note: afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
it's done all the time. the slab is sawcut, the earth trenched, plumbed, backfilled & the concrete placed & finished.
sub-slab should be prepped -- compacted earth & vapor barrier. also, rebar gets drilled into existing slab every foot or sixteen inches so that it will not let the new concrete sag.
Old 6/13/07, 7:42 PM
Dennis R. Goudreau Dennis R. Goudreau is online now
I agree Andrew I had this same thing done in my house changeing out old cast pipes not a problem at all
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
