Hey Guys-
I didn't see any signs that these "posts" weren't supporting the overhang, but are these adequate supports for it? Thanks. Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
| Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
See this older thread....pay special attention to post #9.
Are we engaging in enginneering services with this? Tread lightly.
8 Ft. 3 Scroll Flat Column - 2 Columns per Bundle "Flat & corner configurations, can be used with any rail system for porch or patio overhangs. Not designed for structural support." 8 Ft. 3S Corner Column - 2 Columns per Bundle "Decorative 3-S Design Corner Column. Add Beautify To Your Home With This Classic Design. Fits With All Village Ironsmith Railing. Touch Up Painting & Annual Painting Is Recommended. 2 Columns per Bundle" These columns can be found at homedepot.com LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
"Not designed for structural support" will be the foundation I use for reporting it. A challenge could be how do I know that the ones used in this installation weren't from a manufacturer that did design them for support. I didn't see any labeling on them to know where they came from. At any rate, I'll identify it and if they want to pursue it further with a structural engineer they can do that. Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
Boy, that makes me want to go out and buy one of their products!
Kenny, Gilpin (like we agree may or may not be the mfg of the columns in your case) also publishes this working load table. They re-affirm their disclaimer at the top of it.
Decorative Columns Working Loads.pdf |
I think over the years of manufacturing, they found people with no common sense and structural collapses might have occured, so they put this warning to protect themselves from abuse to usage.
Since the Manufacturer of the porch column is unknown, it might be wise to note such, that there is no evidence to dictate that the wrought iron porch columns are adequate without having it engineered by qualified personnel. The working load for the design of these porch railing columns vary from Manufacture to Manufacture and might not be adequate to continue to carry the anticipated loads. JM ![]() Gilpin Inc Columns Working Loads Revised: November 11, 2008 Based on laboratory tests and analysis the working loads for Gilpin Inc Columns, with a safety factor of five (5), are as follows: NOTES: 1) THESE DATA ARE PROVIDED FOR INFORMATION ONLY. GILPIN INC DOES NOT ASSERT, WARRANT OR GUARANTEE THAT ANY COLUMN HAS THE STRENGTH INDICATED IN THE TABLE OR THAT ANY COLUMN IS SUITABLE FOR ANY PARTICULAR APPLICATION. 2) THESE WORKING LOADS ARE BASED ON LABORATORY TESTS OF TYPICAL, FACTORY NEW, COLUMNS. ACTUAL LOAD BEARING CAPABILITY OF INSTALLATIONS USING PRODUCTION COLUMNS MAY BE SUBSTANTIALLY DIFFERENT, DEPENDING UPON MANY FACTORS SUCH AS: INSTALLATION TECHNIQUES, LATERAL LOADS, AND VARIATIONS (FOR EXAMPLE DUE TO AGE, DAMAGE, DETERIORATION OR MANUFACTURING VARIATION) IN THE PARTICULAR COLUMNS USED. 3) ANY DAMAGE TO A COLUMN WILL DRAMATICALLY REDUCE ITS LOAD CARRYING CAPABILITY. 4) SAFE DESIGN, USE OF CONFORMING MATERIALS AND COMPLIANCE WITH BUILDING CODES ARE THE RESPONSIBILITY OF THE DESIGNER, BUILDER AND INSTALLER OF ANY STRUCTURE. 5) GILPIN INC RESERVES THE RIGHT TO CHANGE THE DESIGN AND/OR PERFORMANCE CHARACTERISTICS OF THEIR PRODUCTS AT ANY TIME. Style Height (Feet) Working Load (Lbs.) Newport Flat 8 566 Newport Corner 8 1396 Newport Flat 10 562 Newport Corner 10 1255 Windsor Flat 8 779 Windsor Corner 8 1549 Windsor Flat 10 548 Windsor Corner 10 1686 Oakwood Flat 8 985 Oakwood Corner 8 2925 Oakwood Flat 10 511 Oakwood Corner 10 3279 Midway Flat 8 1016 Midway Corner 8 857 Midway Flat 10 604 Midway Corner 10 789 Newport, Windsor, Oakwood, Midway and Gilpin Ironworks are Registered Trademarks or Trademarks of Gilpin Inc.LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Check the bottom of the supports. Hope they didn't look like this.
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
| Deck support barely adequate? | gwilcox | Exterior Inspections | 19 | 11/1/11 4:21 PM |
| Another way to support a house | dvalley | Exterior Inspections | 3 | 10/30/09 3:45 PM |
| Where do I put the Aquarium? | mcyr | Structural Inspections | 3 | 11/6/07 3:05 PM |
