| Structural Contains discussions about the structural portion of a home inspection. This includes foundations, framing, et cetera. |
john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
if you choose, click FORUMS, click Foundation Systems Forum and then scroll down `n click TOPIC Cinder Block Wall Cracking...... http://www.inspectorsjournal.com/ See Photos, see cracks in basment wall Now, here are some of the Hm Inpsectors thoughts/ideas/beliefs 1) one inspector asks... 'what caused the water in basement'? Then talks about possibility of the grade being the problem and then the possibility of the downspouts being the problem. WRONG answers! This is part of what sellers/buyers are being told, its freakin` WRONG! Jesus Kristmas! 2) another chirps in, is curious about water table, then says Waterproofing cracks is EASY!!! Says to inject cracks on INSIDE.... hey, this is a BLOCK WALL here, hello!!! UN-believable NONSENSE. 3) another chimes in, says advise given so far is 'sound'. Okie dokie 4) potential buyer posts back `n states the grade slopes away,downspouts direct water away blah blah blah and talks about noticeable 'black coating' and assumes this wall or part of wall was waterproofed. It may be someone only damproofed part of wall, didn`t use hydraulic cement and din`t backfill w/all peastone/gravel. Or someone dug down 1-2' and applied some tar/asphalt,not going to 'waterproof' entire depth of cracks or wall. Run a dang hose on outside, right up against the wall, let water run up to an hour if one has to, you`ll find out if it leaks. If these cracks were not waterproofed and wall wasn`t backfilled with gravel then THATS WHY the sucker leaks...CRACKS!!! Raising the grade, extending the downspouts,patching the cracks on inside or injecting them does NOT solve the problem(s)....CRACKS on the outside, sheesh! ---Next TOPIC, Basement Foundation Waterproofing Repair Client had INSIDE of walls sprayed w/ silicone sealant $10,000..... Rains came and it leaks, company who blcccht`d HO comes back 2 more times to apply more garbage on inside, etc. common sense comments from most other HI`s but the first witht he client says...'for the price of waterproofing repairs, they could have had a new driveway that would have PREVENTED the moisture issues'. .....another WRONG ANSWER! Last guy says/assumes.... 'problem could have been solved quite well by using CWM' one brand being Xypex. W t ??? How is applying these products on inside of walls defining HOW-WHERE water is FIRST entering. Most often its because of cracks on outside of block wall,openings into house around/above the grade, bsmt windows/open mortar joints etc. Applying this crap doesn`t DEFINE the problem(s) and won`t repair `em. Back to driveway... If the problem/leakge was due to cracks/other openings in the wall then THATS what needs to be repaired, not the stupid driveway. If the problem/leakage was due to a blockage in the lateral-line or blockage in tile that empties into a sump pit then THATS what needs to be repaired/snaked-correctly. New driveway isn`t going to solve these potential problems either. Its NOT about the stupid GRADE, its NOT about the stupid downspouts not being long enough, its NOT the stupid driveway!!!!!! Please QUIT with all these MYTHS. Got MILK? Last edited by john bubber; 12/8/07 at 8:57 PM.. |
Damn, that is funny Mark.......
Dale Duffy 602.402.5305 Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Your Leaking House-- Your Leaking House Message Board InterNACHI 2007 U.S.A Member of the Year |
It's a common phenom in HI bulletin boards. Sight recognition of a problem from one blurry and dark photo followed by more BS put out than a Russian radio station. Like rearranging deck chairs on the Titanic while it sinks.
Ha......HAAAAAAAAAAAAAA!
another MYTH
this crap goes on `n on `n on, a continuance of misinformation looks like 4th Q and A http://www.dailyherald.com/story/?id=91423&src=118 HO has block wall, prior-owner painted block walls, gets water in bsmt. answer in-part says.... 'i doubt that the paint is a waterproofing coating.If it were you`d have NO Leakage'. what the!!!!!!!!!!!!!!!!!!! On and on and on and on and on and on! PAINTING inside bsmt walls cannot, does SNOT, will never stop/prevent water-moisture that enters on outside, through-cracks and other openings. Won`t stop/prevent mold,efflorescence or insects from entering either....dammmitttt! -Foundations CRACKS provide HIDDEN Entry-Points for the beloved Termite -Points of entry http://www.utoronto.ca/forest/termite/tips8.htm -Mold http://abcnews.go.com/WNT/story?id=131638&page=1 "Experts agree on one thing: if you`ve got mold you need to get rid of it.MORE importantly, you need to eliminate the CAUSE" "Find the moisture, ELIMINATE the moisture, clean up the mold" "LOCATE and fix leaks immediately" "Cleaning up the mold is not enough. You MUST FIND the WATER SOURCE and eliminate it" Got MILK? ![]() F Mac, Stevie Nicks....got milk? http://www.youtube.com/watch?v=iwsPw...eature=related would you? Oh....Stevie, if you have a leaky crack, i will seal it up fer ya sweety! Ann and Nancy too.... http://www.youtube.com/watch?v=jxfdDrKO8uM Last edited by john bubber; 12/9/07 at 9:42 AM.. |
