I would like to see some
David Pyramid Home Inspections |
Just did this one. Kitchen juts from the house. Notice the lean, then notice the two cracks in the cupboards on each side of the kitchen where they meet the existing walls.
todd |
I found this wall deflection on a 11 month warranty inspection. Builder later took off the drywall cover and found the header twisting in place from drying, pulling the wall studs and all with it. You can see the patch area the home owners had done to fix the cracking in the drywall previously and thought it was "normal" settlement surface cracking since it was a new home.
Peter Doane Realty Check Inspection Service NACHI ID# 05120681
cgoyette is a non-member guest and is in no way affiliated with InterNACHI or its members.
yea ridge board 2 inches short classic "use what you have".
Three year old home. Main beam had warped so that the right edge of the beam was now where the left edge used to be. They ended up replacing a 12 foot section of the beam. Gotta love that green lumber.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County Last edited by sstanczyk; 3/22/09 at 1:28 AM.. |
1. 125 year old home, load bearing wall resting on stone rubble and rock.
2. Same house built up rim joists, rot, wood/soil contact. |
Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Here's some, hope they help.
scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
More
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
Skip Erwin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Funny you should ask. I ran across this today. The house,the chimney, or both are shifting.
bump .
and what's a strucural? David, What in particular are you looking for? Nick's paying $3 or more for photos ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
| pre-purchase not a guarantee | rcooke | Canadian Inspectors | 41 | 11/26/07 7:30 AM |
| Defects as described by Lawyers | mcyr | Miscellaneous Discussion for Inspectors | 3 | 10/28/07 7:58 AM |
| Pictures of electrical defects | jtedesco1 | Electrical Inspections | 5 | 5/24/06 11:44 AM |
