| Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Joe:
Lets make this one educational. It is an extreme example of what not to do. I don't know where they would get info from to do a double brick wall in this way. I will start Bolt sill plate to foundation using J-bolts. Seal between the sill and foundation with insulated strip. Apply flashing to direct water away from foundation. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Greg Mathias, CCHI Journeyman Carpenter Global Property Inspections Lloydminster, AB. Canada (780)205-9912 |
The double wythe wall was at the garage. The rest was pier and curtain wall.
Can you put bolts in brick?
I have seen ones designed to hold up decks on a ledger board tied into brick veneer but I can not speak about installing them into this designed foundation. Like I said I have never seen this here.
If this is the garage. Why would they build it this way?
It looks like they have filled all the holes with mortar. One freeze and they are going to have snapped bricks. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Simpson does make a split strap masonry foundation anchor that looks like this ...
![]() ![]() Dont know if the install for that strap is acceptable .. you would have to get the info off the strap and call the manufacturer. JMO & 2-nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
"Do not use in red clay brick." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I agree about the strong tie. They may be used in block and poured concrete but can't speak of them being installed in brick.
Even if they were according to your picture someone has installed them wrong. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
A very common structural defect.
The longer Simpson MAB anchors can be used for brick at a reduced capacity (wouldn't fly in my area with the high wind loads). They do make similar heaver duty ones (also longer) for use with brick foundations ... I will see if I can find a pic.
Thats why I recommended getting the info off the strap and checking with the manufacturer if there is a question. But be careful how you write this one up, because designers can also do a capacity calculation for brick if the manufacturer hasn't done that testing to list values in the calalog (they typically don't test them in brick due to the extra costs). Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 8/4/11 at 4:05 PM.. |
Would like to see some documentation on that.
Simpson doesn't list values because brick construction varies greatly. Dont know about others. You generally need job specifics (e.g. f'm). Are you saying the anchors would have a zero capacity in brick?
| Free Books And Articles For Electrical | jtedesco1 | Electrical Inspections | 14 | 1/6/08 6:45 PM |
