I came across this yesterday on a draw inspection. Interesting product.
This footing form system stays in place an provides foundation drainage. Link to product. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Wonder if accepted by codes now to replace 4" drainage pipe required at footings? |
He told me cost more but he doesn't have to pull and clean form boards and you also don't have to rely on the drain tile installer to get the tile level and the gravel bed right. He puts the drain basket in and makes the terminations. If I ever build again I will specify this product. It can also be adapted for Radon control easily. It should be better than a single 4" drainage pipe as it drains both sides of the footing. Sweet. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
| Inspector in hot water after approving unit without drain | rcooke | Canadian Inspectors | 7 | 2/20/08 3:59 PM |
| Child eviscerated by pool drain | mthomas2 | Ancillary Inspection Services & Additional Topics | 26 | 7/16/07 4:27 PM |
| French drain tied into main drain | rwashington | Plumbing Inspections | 6 | 2/16/07 11:04 PM |
