What you say about these defects in the framing of the attic?
Thanks! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified Vermont Home Inspector (and anywhere else in North America) |
Hi Buck,
I'd say its FUBAR'd, I'd be recommending a qualified framing contractor as a minimum, thats "Harry" work, between the miserable connections and the splitting timbers it looks like it could let go at any time. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
I agree Gerry, this has got to be the worse hack job created by Joe the Plumber or his friend that I have seen in a while.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks! Gerry, that is exactly what I did.
Knowledge You Can Trust... Service You Deserve |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Still trying to figure out whats going on there John, like I said I'd love to see the engineered plans for that set up Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Buck,
A lot of the problem is due to extremely poor quality lumber and not great quality workmanship. What failure did you see in the roof system? Sagging rafters? It's obviously ugly and the split rafter and purlin brace should be sistered, but I see a purlin system that looks mostly correct for what appears to be the time period. Braces every other rafter, a strongback with a bad spot that had an extra brace thrown in to support it. It looks like it's been that way for a long time. So aside from ugliness and some areas that need some work, did you see a lot of failure? Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Kenton, I am with Gerry, still trying to figure it out. So far the last pic appears to be a dormer built onto the main roof and it is not done to standards. Should have had sheathing over the main roof or have had dormer trusses.
This has got to be the most screwed up framing mixture of trusses and field built add-ons that I have ever seen. JMH
Hi Marcel,
To me, John,s photos look like someone tied in a smaller roof using conventional framing. Usually in the frameover they sheath the lower roof first, but I don't think it's necessary. The flat boards carrying the bottoms of the conventional rafters just need to be strong enough. I know it looks crazy, but was probably just cheaper to finish out the framing of this smaller roof using conventional framing instead of ordering trusses. The cuts on the conventional rafter don't look too bad. Those look like gun nails. Framing this wierd has to be about saving money. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
It's a new build, looks like dynamic design. I had to call it and let someone else determine if the flat boards a strong enough.
| Mold question? | ccurrins | Interior Inspections | 35 | 1/23/09 11:55 AM |
| Truss Uplift | rcooke | Canadian Inspectors | 5 | 2/26/08 7:43 PM |
| Spray Foam to the Rescue ? | mcyr | Structural Inspections | 3 | 3/27/07 7:29 PM |
