Just curious.....On NEW construction. Do all of you call out attic stairs if they are installed backwards? In other words you have to turn around and be a contortionist in order to access the furnace. I do . Your thoughts please.
Generally, just for using drywall screws instead of nails, as called out on the instruction sheet that is glued to the cover, and for a non fire rated cover, may see 2 out of 100 that are fire rated, but they will fire caulk the holes that the romex and phone lines run thru, go figure.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
An interesting potential can of worms.
Lots of theoretical Q's & A's like; How were the placement of each indicated in the prints? The framer was there before the HVAC sub so the stairs were most likely there first so who would be held to the fire??Were both trades limited by space above and below?If you turned the stairs do you then walk immediately into the furnace? We would all agree that access to equipment is vital but in the case you are discribing,and without being there,It sounds like the unit is accessible albeit difficult. Personally,I would make the potential homeowner aware of its difficult position but not call it out as a defect . |
New product from Werner in latest JLC.
http://www.wernerladder.com/televator/ |
that is a nice product!!
Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
I have called out an equipment deck that is not large enough to allow for you to safely access the furnace. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I will report a light switch in the attic that is on the wrong end of the stairs.
Did a re-inspection today where the builder moved it to the right place. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Bruce,
Same here on light fixtures at the top of the attic ladder. As soon at the person enters the attic they are hit in the face with the bare light bulb. Someone with a box could easily break the bulb, showering glass onto themselves. All one has to do is break one once with their noggin to know it isn't fun. |
| Attic Temps | mroe | Miscellaneous Discussion for Inspectors | 12 | 8/26/07 9:32 AM |
| Question about pull down attic stairs | waksell | Interior Inspections | 33 | 4/1/07 11:11 PM |
| Spray Foam to the Rescue ? | mcyr | Structural Inspections | 3 | 3/27/07 7:29 PM |
| Attic Inspection | rbritton | Electrical Inspections | 19 | 8/2/06 2:58 PM |
| Attic Temperatures Can Pose Serious Risks | jtedesco1 | Interior Inspections | 4 | 4/2/06 10:17 AM |
