Hey Guys-
This is wrong correct? I'm seeing a lack of ledger fasteners, only a 2x6 ledger, and no joist hangers. Where the joists connect on the stair side, is it okay to attach those using screws from the outside like they did, or should there be joist hangers there as well. Just wanted to double-check before I get a call from the builder on this new construction property. Thanks. Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
| Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Can you get your hand around the handrail? or i should say can you grasp it.
INSPECTIONLOGOS.COM "I can keep explaining it for you, but I can't understand it for you". Nick G. Monroe Home Inspection |
At minimum it needs hangers, and block at ledger board should have at least 1/2" bolts/screws. I can't see enough of ledger board to determine if required number of fasteners were used..
It needs to be lag bolted or through bolted to the structure and it does need rust resistant hangers and fasteners. I would also expect to see the joists terminate onto a beam so that front board at the stairs should be doubled up and have a double hanger on the one end and be bolted to the 4x4 on the other end. Also if it's just untreated framing lumber that's not acceptable. It should have at least one continuous railing 34-38" high. Many local building departments have deck cheat sheets.
Thanks guys. I think I have plenty to go off of. I was also sent a nice link to a wood deck guide that has lots of information as well:
http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf Rigler Home Inspections Hays, KS 67601 785-656-0272 Last edited by krigler; 11/4/10 at 10:35 AM.. |
There is no visible flashing and it is installed directly against the siding. Looks like Hardiplank, and their instructions prohibit direct contact with other surfaces.
Thanks Joe. I'm with you on the spacing between the deck, but how far does Hardiplank go with no direct contact with other surfaces. Dryer vent, chimney vent, electrical boxes, etc??? Or am I just reading that wrong?
http://www.jameshardie.com/pdf/insta...eplank-hz5.pdf “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
That's modern practice, but required? Anyone got an IRC reference?
page 12, 13 Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Just out of curiosity, what is the difference between a "Deck" and a "Landing"?
or is there a difference? I don't know myself |
That looks like a pre-fab set of stairs usually installed on MFG housing, if so the correct joist fasteners may be there just not visible.
Russell Inspection Services New Hampshire state license # 57 Level I Thermographer, ITC Certified Building Science Thermographer, ITC Certified Building Analyst, BPI Certified Commercial Inspector, ITA Certified Septic Evaluator, GSDI #148 www.newenglandthermalimaging.com www.russellinspectionservices.com www.nhsepticinspection.com |
It says that IRC requirements are bracketed and the information on pp 12 & 13 are not bracketed and so are not building code and not a requirement. This is mostly a "best practices" document and it's a good document, but I wouldn't call that staircase and landing defective for lack of joist hangers. If joists are toe-nailed only, each connection should each have 3 in one side and 2 in the other, 16d vinyl-coated sinker or bigger. It's hard to see the lags into the rim. If ledgers have less than one 1/2" lag a min. of every 24" staggered up and down and two at each side of each break, I call it defective. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
| Using the Prescriptive Residential Deck Construction Guide | mcyr | Exterior Inspections | 0 | 7/21/09 7:10 PM |
| Roof deck question | wdecker | Exterior Inspections | 3 | 11/17/08 10:17 PM |
| Roy Cooke Removed from NACHI | rcooke | Canadian Inspectors | 720 | 7/20/08 4:10 PM |
| Illinois State Chapter of InterNACHI DECK FRAMING/CONSTRUCTION COURSE | ksitzes | Miscellaneous Discussion for Inspectors | 6 | 3/4/08 5:47 PM |
