Basement condo.
Front entrance descends down 5 stairs. In front of the main door is a recessed area. 36" wide 40 inches long ( facing ) 5 inches deep and acts as the drainage for the basement patio. It has the 4" plumbing with screened top and leads to the garage catch basin. Normal. You have to step down to go in your home and step up to go out. It is all part of the slab, monolithic pour. Then above is a normal basement patio.. No photo's yet. Will be doing the inspection within 4 days. Is this OK. My thoughts are safety hazard. #1 would it be considered an egress? but it is only 5 inches high. Remember the door opens into the 5 inch depression. #2 if not an egress then would it be described as a lower landing. 36" wide 40" long and 5 " deep. Also acts as the drainage. All the land slopes away from the building by more that 3" per 10 feet. 5 year old build. Thanks. Thoughts please. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
| Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Robert,
Much would depend on the occupancy class. On my side of the border if this were a 1 and 2 family dwelling the conditions you describe would be compliant. If it were a multi-family condo then it would have too comply with the American Disability Act for Accessibility. Meaning that the door could not rise above the landing by more than 0.375 of an inch (9.5250mm), the landings would be required to be 60" (1.524006 meters) in direction of travel and could not slope more than 2% Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
Thank you Mr.Tyson.
As you see I am just learning the fundamentals of report writing and want to be most accurate. I will look under occupancy class for multi-family condo. Thank you. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Mark,
the doors threshold is bellow the landing slabs grade and within a basin. In an area of recess or a Detention basin within the egress. 40" inches by 40" inches to make it more visual and used for drainage.. The landing should be gently " sloped to the drain " but it is not. It is a basin. Leaving or entering the front door to exit the unit there is a basin you walk into or onto. ( depending if you are coming or going.) # 1: Leaving the unit one walks onto drainage systems basin. 40" wide 40" long. " a Detention basin " an artificial flow control structure that is used to contain flood water for a limited period of a time " built within the slab,) #2: then one steps up 5" inches onto the main landing slab which is the patio landing. All below the ground. # 3: Then you walk up 5 steps to gain access onto street level.. The egress or means of exit or entry to the unit. That is why I used the term egress and Detention basin. I will bring photos today. I have never seen this and question it is code' Yes we are not code inspectors. It looks like a safety concern for one.. DIV.Ov {width:550px} e·gress ( ![]() gr s ) n. 1. The act of coming or going out; emergence.( its not an emergency egress )2. The right to leave or go out: denied the refugees egress. 3. A path or opening for going out; an exit. 4. Astronomy The emergence of a celestial body from eclipse or occultation. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Attachment 45663
Attachment 45664 Here are the photos to the egress that is the main entrance. I though the landing was bigger. Its the one next door. HD photos if any one is interested in keeping them on file. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 Last edited by ryoung7; 10/5/11 at 10:36 PM.. |
So it looks like that depressed area could be considered the "landing" for the door if long enough, which is allowed to be about 8" lower than the door as long as the entry door swings in. Then there is a step up to the basement patio area. They may have done that because the drainage for exterior basement entrances are problematic. When (not if) the drain clogs at least it wont start flowing into the unit right away. As a minimum I would provide notes in the report about maintaining the drainage to avoid water entering the unit. JMO & 2-Nickels ...
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Thank you Robert.
Looking for Quebec code book this weekend. PS: More than 2 nickels sir, and great opinion. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
| Renovating Your Basement for Livability | mkyriacou | Canadian Inspectors | 0 | 10/22/09 11:45 AM |
| Site grading and drainage | wdevries | Canadian Inspectors | 5 | 10/6/09 10:23 PM |
| Basement egress... | jcampbell | Interior Inspections | 6 | 9/23/09 1:16 PM |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
