This is one I've never encountered before.
The basement floor is poured concrete and appears to be intact. Minor common cracks in some areas but nothing out of line to the norm. If an item is left on the floor for a period of approximately 3 days a puddle of water appears under the item. Doesn't matter what the item is(cardboard box, plastic pail, wood, etc.) moisture or a puddle will form. Anybody have ideas as to what may cause this and a possible remedy? Thanks Allan Allan Berdahl Aarlan Home Inspection Services Calgary, Alberta Bus: 403-808-5355 Cell: 403-803-4064 Fax: 403-204-8863 Email: aarlan@telus.net |
Hi Allen,
it's probably caused by capilliary action wicking up water to anything on the surface, could be caused by a poor concrete mix, maybe a floor sealer might help, but I'd talk to a damp-proofing contractor. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Sounds like they may have forgot to put down a moisture barrier (usually 6 mil poly) prior to pouring the basement slab.
zackly...
Thanks guys. Sure seemed weird. Had never seen this before.
Allan's in Canada. No moisture barrier required, just 4" of granular fill.
I like the block of a barrier myself and believe it is the best practice. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
| Site grading and drainage | wdevries | Canadian Inspectors | 5 | 10/6/09 11:23 PM |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 2:30 PM |
| Legal: Buyer points blame at sellers when basement repeatedly floods. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 0 | 6/10/08 3:42 PM |
| gutter downspout to basement drainage system | David Paterson | Exterior Inspections | 2 | 12/18/06 7:27 PM |
