Old 1/4/09, 2:09 PM
Vince Santos's Avatar
Vince Santos Vince Santos is offline
Thumbs down Basement Repair
These areas had what appeared to be an epoxy type material oozing out in several areas with what I believe to be hydraulic cement mopped over. The areas actually tested dry but I have my doubts as to the effectiveness of these repairs.
I'm fairly certain this was a homeowner special type repair. What would you note in the report concerning this.
Vince Santos
StepByStep Home Services LC
(734) 748-9584
Providing Home Inspection Services to Southeast Michigan
facebook
ITA Trained and Certified
Old 1/4/09, 2:50 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Default Re: Basement Repair
Just going by your pictures, I would recommend client obtaining repair invoice/ info from homeowner. Any reputable foundation repair company provides a transferable lifetime warranty. If no invoice/ info is available, I would recommend evaluation by a foundation repair contractor.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 1/4/09, 3:11 PM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
Doesn't look like a pro did it to me Vince. I would follow Robert's advice.
Bill Boerner
STL Home Inspection Services LLC
Serving St. Louis/Surrounding
(314) 805-2137
office@stlhomeinspector.com
http://www.stlhomeinspector.com
Residential, Commercial, Radon, Termite, Lateral Sewer Scopes
Old 1/4/09, 3:15 PM
Obviously a Novice repair.
I would be curious as to what was being repaired.
Was it a shinkage crack or a structural crack?
Sure looks like a hydraulic cement used to try and stop a leak, explaining the streaks.
Recommend a foundation repair expert/waterproofing contractor on this one.
Problem may be on the exterior.
If a structural crack, it will open up again.
Marcel
Old 1/4/09, 3:31 PM
My client said the "homeowner repairs" were not there a week ago so I know it was done relatively recently. Unfortunately he did not remember what the area looked like prior to these repairs.
One other repair looked like it was performed by a contractor.
Thanks for the comments and good advice.
Vince Santos
(734) 748-9584
facebook
Old 1/4/09, 3:39 PM
Vince you come across some whoppers lol
Bill Boerner
(314) 805-2137
Old 1/5/09, 3:58 AM
john bubber john bubber is offline
Unmoderated Guest
Please Note: john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
Sometimes those who do injections talk homeowners into an injection repair when its not needed. Not needed meaning, the crack did NOT penetrate,go through to the exterior,some are super thin,crack goes into wall maybe 1/2-1" or less, and of course wall is 8-12" thick.
Another thing about these injections is they do not repair/seal other exterior openings just above the crack where water first-enters and so water can/will still enter on inside,usually up high on wall,right where the crack is seen http://www2.snapfish.com/slideshow/A...6/t_=122238283
Water can first-enter here....and through other gaps/crevices/openings above the top-of-crack and inside the basement it`ll look like the crack leaks up high (sometimes mid way) on wall inside basement.
Don`t mean to go on forever!! Trying to point out several scenarios/possibilities.
This is why i`ll often run a water-test,especially if its a shrinkage crack or any thin-hairline crack because, if crack doesn`t penetrate to the outside then homeowner doesn`t need repair....if they were seeing water then the water is sometimes ONLY entering through gaps/openings above the wall, as seen in pics. Sure,some HO`s will want something done w/crack anyways,ok,if thats what ya want fine but if i just ran water,LOTS of water on the outside of shrinkage crack etc and NO water enters,nary a drop. Just showed em the crack does not extend to outside....water is first entering through OTHER exterior opening(s).
Of course we`ll run water above the crack to prove this,like soaking/spraying the basement window or open joints etc.....and THEN water enters,then they`ll see water on inside.
On the other hand,some teeny tiny lil hairline cracks do penetrate http://www2.snapfish.com/slideshow/A...6/t_=122238283
Ran water test to show homeowner AND my own azz that, yes, when i run water from ground-level down it does enter through the crack. Tells me crack penetrates to outside and needs to be waterproofed and/or are other openings,depends how one does the water test/where ya run water.
Sometimes INSTEAD of runnin` water test i`ll just dig out,dig down 6-12" and brush wall and see if crack penetrates to outside. And if grade is a lil low,you can see the TOP of wall outside then you may see the top of the crack(won`t need to dig/run water),may have to brush wall.
Same here,can barely see it but it does leak/allow water in,did water test http://www2.snapfish.com/slideshow/A...6/t_=122238283
Same house,see 'other opening' where water can enter. This and other outside gaps above the wall,around basement windows are what injections cannot seal and when ya don`t seal everything the homeowner will leak/see water on inside again.
Obviously,this ain`t no lil crack.No way should any injection be attempted w/these but some bozo` try. In 30 yrs when we`ve been called by HO who had an inside injection done and still leak, we`ve NEVER seen the epoxy/urethane penetrate through the crack to the outside....as many claim. http://www2.snapfish.com/slideshow/A...6/t_=122238283
About 50% of all injection re-leak,this is what we`ve seen throughout 30 years. Several reasons they re-leak, one is, crack widens a lil bit or quite a bit from lateral soil pressure or a porch footing/concrete slab etc
This is one example of why quite a few companies who do injections get call-backs/BBB customer complaints,are incompetent in diagnosing the actual problem and/or only care about getting a job.Example,Crack Team only does injections,had 23 customer complaints within 36 months and still has an unsatisfactory BBB record due to unanswered complaints. http://stlouis.bbb.org/WWWRoot/Repor...firm=310001164 Someone wants to use em go ahead,just trying to point out couple facts is all. Ok,sorry so long!
Old 1/5/09, 8:23 AM
ldapkus ldapkus is offline
I had one that was a hairline crack at the top and opened up to about 3/4" near the bottom and appeared to have been repaired twice. I recommended further evaluation by a structural engineer. Got a call from a G.C. the buyer had hired and he said the realtor told him it was a small crack. I explained the repairs to him and he said he would go look at it because it sounded worse than the realtor described it. I let him know that he had to move the refrigerator to get a good look.
basement-repair-febles-hi-009-640x480-.jpg   basement-repair-febles-hi-011-640x480-.jpg
Site grading and drainage wdevries Canadian Inspectors 5 10/6/09 10:23 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
