Old 11/14/09, 6:39 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Beam Pocket
What would say about this beam pocket and wooden shims???
Thanks!!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified Illinois Home Inspector (and anywhere else in North America)
Old 11/14/09, 9:28 AM
David P. Valley's Avatar
Default Re: Beam Pocket
Buck,
Steel beams should only be supported with steel shims. These steel shims should also be welded to the beam so they will not move out of place. Wood shims (under steel beams) will often crush or creep and will cause the steel beam to settle or fall out of square.
Old 11/14/09, 9:33 AM
Dave,
Would you say anything about the open pocket???
Thanks!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 11/14/09, 9:37 AM
Buck,
No, I've seen many open pocket beams with no issues.
Old 11/14/09, 9:53 AM
Thanks!!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 11/14/09, 11:27 AM
I agree with Dave Buck.
I am curious though as to what the black substance is on the floor joist and the min. bearing for steel beams in the IRC is 3" and 4" in commercial applications.
I also notice that the sill plate on the beam is not bolted and the beam seat should be provided with anchorage for lateral movement and displacement.
Open pockets is fine.
Just an observation of the pic.
Deflected Cantelevered Beam pdickerson Structural Inspections 4 4/3/08 11:16 AM
Steel beam lateral support Mark Ellison Structural Inspections 10 1/16/07 11:40 PM
Steel beam bearing 1 1/2" scosta Structural Inspections 15 6/12/06 10:01 PM
