Client has these under house he put a offer in on, I recommend further review by a structural engineer. Engineer isn't gonna do anyting but give him a quote on drawing something up right. Is this correct. Why not have a carpenter give him a quote just to build it right?
J.Szczesny 4 Seasons Home Inspections Washington State Inspector # 711 800 5th Ave #101-385 Seattle, Wa 98104 (206)391-0285 online @ www.4seasonsinspects.com email @ info@4seasonsinspects.com toll free cal @ 866-512-9972 "For the best protection, get the right inspection" |
| Find an InterNACHI certified Tennessee Home Inspector (and anywhere else in North America) |
arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
Because the "carpenter" was the one who did the work in the first place...
I think in this case it might of been a Carpenter in training.
James, something in the pictures don't add up. I am looking at a fairly recent looking foundation stem wall, a plywood sub-flooring, but on the other hand, I am seeing rough sawn lumber and bridging that brings me back to the late 60's when I installed them and also old piping and insulation that I can not make out. It appears that the beam as you call it might be addittional support for a springy floor or some heavy item was placed in that area that was not initially there at the time of the original build. Was this an old building that was moved? LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I concur with Marcel simply based upon how they framed around the fireplace....if the spans are fine then my concern is the wood in proximity to the ground (termites).
Is that a concrete wall or has it been parched.....cant tell. Jeff |
Me too. Those joists look fine for the span. Honkin' big beams and posts just to take a little springiness out of the floor. Support for a hot tub?
So Jeff, do you recommend a qualified foundation repair conractor instead of an SE sometimes?
Yes I do.
We have foundation contractors in CA that employ SE's - that's what makes them "qualified." IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 7/4/09 at 1:33 AM.. |
I agree Jeff, the only time I call for an SE is if there is visual evidence of a problem. In those picture's it's hard to tell but just the fact that someone added support at some point is not enough, IMHO. I would note it in my report.
Nick should send you a new monitor, so you can help these young fellers better. |
Sorry, didn't have my glasses on.
Well up here it used to be T & G at a 45 degree install. Still looks like a fairly new stem wall though. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Sorry never got back to this thread but to let everyone know, house was built in 1947. Addition which is the new stem wall in the 80's. House had much moisture ant damage. A number of other WDO issues also. Practically needed full gut and remodel. Thanks for all the great remarks
| Deflected Cantelevered Beam | pdickerson | Structural Inspections | 4 | 4/3/08 11:16 AM |
| Steel beam lateral support | Mark Ellison | Structural Inspections | 10 | 1/16/07 11:40 PM |
| Steel beam bearing 1 1/2" | scosta | Structural Inspections | 15 | 6/12/06 10:01 PM |
