mjones1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Can a 8 1/2" x 13 1/2" beam safely span 24 feet?
Mike |
Off hand, I can't say.
What was the loading?...How long has it been there?...Was there any deflection? |
Also, what material or species is the beam made from? How is it loaded?
We need to know what the composite of the beam consists of, and the size and loading above. Ex. farm house, dwelling, carport floor, etc.
Marcel |
Michael, you don't have to do calculations or look up Tables of Allowable Spans or determine beam material to follow the Standards of Practice, just call out problems. As Larry asked, was there deflection? -Kent
3 year old 2 story Lindal style home in the flood plane. No deflection noted , gluelam. I have no problem with the install, i was just curious.
Mike |
A ROT for timber, double the depth, subtract 2, this is the span in feet (13.5x2=27-2=25'. This is assuming a rafter condition i.e. uniform loading, fixed connections. Be careful with this ROT because loading points and connections are huge factors in the overall performance of the beam.
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
| Crack in Support Beam | Berry T. Wilson | Structural Inspections | 5 | 5/26/07 4:15 PM |
| Stepped Chimney Span | nwagner | Inspecting HVAC Systems | 2 | 5/24/07 6:13 PM |
| Steel beam lateral support | Mark Ellison | Structural Inspections | 10 | 1/16/07 11:40 PM |
| Steel beam bearing 1 1/2" | scosta | Structural Inspections | 15 | 6/12/06 10:01 PM |
