Old 9/10/10, 10:18 PM
Bruce A. King's Avatar
Default Beveled LVL beam
I found this beveled double LVL on a framing inspection that also holds up the end of another large LVL beam.
I reported the need for the engineers drawing since I knew it could be correct as is but had some doubts due to the loads on it.
The builder sent my client the drawing and specs, it indicated a 5 1/2 inch heel at the end of the beam and a 5/12 bevel slope. An email also came with it that stated " the calculations are correct on the beam".
I went back for the predrywall and framing reinspection and actually measured it since I knew it did not have a 5 1/2 inch heel.
In case the pictures ended up too small, the heel came out to be 4 inches and the bevel was wrong too so its back to the drawing board......
I hope I get to go back and see what the repair looks like.
beveled-lvl-beam-imgp0132.jpg   beveled-lvl-beam-001.jpg   beveled-lvl-beam-002.jpg   beveled-lvl-beam-003.jpg
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/14/10, 8:32 PM
Kenneth Dolin's Avatar
Kenneth Dolin Kenneth Dolin is offline
Default Re: Beveled LVL beam
let us know
Ken Dolin
Kenco Home Inspections
WWW.Kenco.org
State of Florida Licensed Home Inspector HI 59
Old 9/14/10, 9:16 PM
They provided a new engineers drawing and letter that indicates the beveled beam is still within the design numbers.
704 301-3207
Old 9/14/10, 9:46 PM
Jeffrey R. Pope's Avatar
The heel should be measured at the minimum bearing point, which is generally 1-1/2". Is that about where your third picture is?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/14/10, 10:46 PM
No, the 2nd picture is the heel as indicated on both of the engineers drawings. The end of the beam should have been 5 1/2 inches tall according to the original plans which would have made the height in the third picture over 7 inches.
What did you mean by the 1 1/2 inches? The top plate is 3 1/2 inches bearing surface.
704 301-3207
Old 9/14/10, 11:25 PM
Generally, beams and such require a minimum end-bearing of 1-1/2" on their support, whether it be a "plate" or other type of supporting wall.
So the heel can technically be 5-1/2" at that point, which is about half way onto the plate. Anything past that is just "extra."
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/14/10, 11:41 PM
The engineers drawing showed the entire 3 1/2 inches of bearing surface as being used or required. LVL beams typically require 3 1/2 inches due to the extremely high loads. Sawn lumber beams are good for only 1 1/2 bearing in most cases.
704 301-3207
Old 9/14/10, 11:47 PM
That's really all that matters. I've seen glue-lams and LVL's at 1-1/2", but it's up to the engineer.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Deflected Cantelevered Beam pdickerson Structural Inspections 4 4/3/08 10:16 AM
Steel beam bearing 1 1/2" scosta Structural Inspections 17 6/12/06 9:01 PM
