Old 1/19/13, 7:53 PM
Kenneth Blair Kenneth Blair is offline
Default Block Foundation Dry Stack
This block foundation wall was a dry stack which did not include the use of mortar to bond the block. The cells of the block were poured with concrete in approximately every fourth block. No failure of the foundation wall or movement was noted. The wall had 5 courses of block on top of a concrete basement foundation wall. So I was not concerned that much with settlement. I was more concerned with lateral movement from soil pressure and moisture intrusion. Just haven't seen this before and wondering how much of a deal you guys would make of it.
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/20/13, 7:13 PM
Default Re: Block Foundation Dry Stack
No responses??
Old 1/20/13, 8:00 PM
Juan C. Jimenez Juan C. Jimenez is offline
Hey Kenneth. A couple of weeks ago I spent a few hours reading about dry stack foundations. If you google it, you will find plenty o information. More than you will find here apparently
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Richmond Radon Testing
Recommend Us!
Old 1/20/13, 8:50 PM
Thanks Juan
Old 1/20/13, 8:57 PM
Jeffrey R. Pope's Avatar
I just have a hard time understanding this type of "construction." I can't think of any circumstance where I would consider a "dry-stack" to be acceptable for the foundation of a structure.
Maybe I've just been in CA for too long...
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/20/13, 9:38 PM
Yeah IDK. Seems lazy to me. I looked it up when someone posted a photo here that may have been a dry stack. Apparently some people think it works.
Juan Jimenez
God. Family. Home.
804-269-4321
Recommend Us!
Old 1/21/13, 8:43 PM
I'm with you Jeff. I am having a hard time accepting this one too. I pointed it out to the buyer and told them it was unusual and what I thought the disadvantages were. I suggested that they do their own research on it. You could actually see outside light between the blocks. I never thought properly laid block walls were that difficult.
Old 1/21/13, 8:53 PM
You shouldn't be able to see light from what I read. The cells should be filled and the both sides should have a surface bond. Keep us updated.
Juan Jimenez
God. Family. Home.
804-269-4321
Recommend Us!
Old 1/21/13, 11:36 PM
It's much easier for me in my state. This type of "foundation" (if you can call it that) would be referenced as a major structural defect. You wouldn't be able to get insurance on a structure built like that...
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/22/13, 3:31 AM
john bubber john bubber is offline
Unmoderated Guest
Please Note: john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
Can remember only 3 of those types we've done/waterproofed.
All had gaps/openings between the top-of-the-poured wall and first course of blocks. Don't have pic's of those sry.
Here's kind-of what i mean.....
http://picasaweb.google.com/10104903...50623989661666
Here,gaps at-along bottom of poured wall and footing, see scrapers.Some water entered here.
Could also stick a scraper (water was entering) those 3 between top of poured wall and blocks. These few were NOT deeper than 5 1/2' and no wall longer than 30' (bungalow's)so maybe that is why we didn't see any bowing at,that-point-in-time.
Vertical crack through block foundation mdeacon Structural Inspections 12 2/24/10 10:18 AM
Masonry Block Foundation Repairs dmacy Structural Inspections 1 6/3/09 4:05 AM
Dampness in basement- new construction jcundiff General Inspection Discussion 47 6/21/08 11:35 AM
Concrete block foundation rwand1 Structural Inspections 4 10/3/07 12:11 PM
