This was a small addition (more like an extension) to the rear of a kitchen. A footing and slab was poured and 2 courses of block support the 4 foot "addition". The corner blocks have kicked out at one corner. There does not appear to be any settling or currently any movement of the structure above it.
Any comments? David Nice National Certified Inspection Services, Inc. Wauwatosa, WI http://www.nationalcertified.com 414-979-6900 President WiNACHI http://www.winachi.com Wisconsin InterNACHI Chapter |
I see the snow. Is it possible that water got behind or in between the block and froze to push it away?
David,
Is the footing below the frost line? Maybe it's not deep enough and what you are seeing is frost heave damage JMHO |
That would have been my question as Michael just mentioned.
Is this foundation below the frost line? It appears as the frost action has laterally applied the forces to the block wall and if not anchored properly to the sill of the house, would explain why you did not notice any movement within the dwelling. JMO Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Of course if I knew that I wouldn't need you guys now would I? Too bad the seller recently had a massive stroke and can't talk.
If you did not hear what you wanted to hear, I guess we opologize for that and wish you luck in figureing it out on your own. Thank you/. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
2. It is pretty much all speculation without an expert evaluation, just though some people would have something useful to add. A group of local inspectors had plenty to say and suggest. 3. I had no expectations of hearing one thing or another. David Nice National Certified Inspection Services, Inc. Wauwatosa, WI http://www.nationalcertified.com 414-979-6900 President WiNACHI http://www.winachi.com Wisconsin InterNACHI Chapter |
jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
and I'd recommend that the guys keeps taking his meds !!! Mic |
| Furnace kicking on.. | rfarnum | Inspecting HVAC Systems | 21 | 2/10/07 6:33 AM |
| Squash Blocks | apolillo | Structural Inspections | 37 | 11/25/06 3:43 PM |
