Old 6/12/06, 8:06 PM
David C. Macy's Avatar
Default Breezway slab & missing support beam.
As I inspected the breezeway and observed both doors being out of align, I noticed the slab being cracked and settled.
The owners rushed over & stated we have a carpenter coming out to align the door. I stated that you should have a structural qualified professional fix the slab.
The basement had a solid block wall and then busted it out to add a bar. They never installed a beam. When I moved the panels a bird fell on me. I couldnt figure where he got in.
This home had half of the foundation drainage replaced and they should of replaced all of it.
The roof leaked and was at a improperly wired light. I am glad I moved the panels.
This house had a lot of hidden problems.
Dave
ID:	4006   breezway-slab-and-missing-support-beam-72106-parma-011-small-.jpg.jpg
ID:	4007   breezway-slab-and-missing-support-beam-72106-parma-044-small-.jpg.jpg
ID:	4008   breezway-slab-and-missing-support-beam-72106-parma-008-small-.jpg.jpg
ID:	4009   breezway-slab-and-missing-support-beam-72106-parma-026-small-.jpg.jpg
Old 6/12/06, 8:39 PM
Default Re: Breezway slab & missing support beam.
Not sure what I am looking at, but appears that Pic #1 needs to have the bottom glider rollers adjusted to aligne the doors if they are sliders.
Pic #2and 3 not sure what I am looking at.
Pic #4 appears to be a cast iron bell and spikot pipe for underdrain and gutters and they must have run out of lead and okom, and used cement of some sort.
Funny.
Pic #5 leak in the ceiling, did you find out where it was coming from??
Marcel
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
Steel beam lateral support Mark Ellison Structural Inspections 10 1/16/07 10:40 PM
Support post for Beam, is this right? mlong Structural Inspections 74 7/25/06 7:47 PM
