Approx. 7 year old home. No kickout flashing. No weep holes. Wet OSB wall sheathing observed from crawl space at the base of the wall. What would you advise the buyer?
My narrative: "Wood wall sheathing was in direct contact with the brick veneer wall, which violates today's commonly accepted construction standards (a gap should be present to allow any moisture on the inside of the brick to drain down the void without directly contacting the house framing). We observed two areas at the front of the home where the base of the wall sheathing was wet and undergoing decay. Note that even if the wall sheathing was covered with asphalt embedded paper or synthetic "house wrap", these barriers are water resistant, not water proof. Therefore, even the presence of these barriers (which is required) would not necessarily prevent the walls from becoming wet if they are in direct contact with the brick. The construction defect described here means that other areas of wet wall framing may exist which were not visible to us. The potential ramifications are decay to the wood wall framing, mold, etc. Note that there is no good remedy and any correction may mean removing the brick from the home, partially or in full. You should consult with a licensed and competent general contractor, residential builder, or engineer about this issue, the possibilities for correction, and the potential costs."
| Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Run!
Good job Joe, I usually add something about the client needing a written and signed statement from any contractor that says its not a problem. As you know, the agents have contractors that will downplay issues when asked to do so, especially in the Rock Hill SC area.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Stone and brick walls can be water proofed.
I suggest this on all new stone veneered homes afte. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Joe, I am a little confused here and maybe you can explain.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Sorry Joe. I though it was stone.
cement brick? montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Does the foundation rise above grade by the 6 inch norm?
How close are brick straiter course to the grading where you notice water infultration? montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Marcel, I didn't say a moisture barrier was absent. I simply said even if present, that's not adequate if the wall was in contact with the brick. The absence of a void prohibited me from observing a moisture barrier, but I doubt it's totally absent....that would be totally negligent.
I could readily see the wall sheathing was in contact with the brick. Whenever I see a lack of kickout flashing, my antenna are way up when I'm going around the perimeter from inside the crawl space. View of the wall sheathing. ![]() How it should be.
“The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 2/14/11 at 7:16 PM.. |
This photo will give you an idea of where the problem is in relation to the grade.
Anyone see any point in doing a IR scan? Would that provide any assurance that the problem was limited to a certain area? Keep in mind that the house is < 10 years old.
Don,t through the baby out with the bath water yet Joe. ( replace all the brick, )
They would have to go on a metal ledger, bumped out. Some corrections can be done but more evidence is needed to explain the areas of concern. ( simple venting, regrade, water proofing ) I think an IR scan would be justified. Someone with prior experience to this type of condition would be needed. That is a tough nut to crack. I would love to spend time investigating the 4 walls.. Good Luck. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Joe try to remember where the defect area's are in relationship to the planting. ( shrubs ) Always keep planting away from building by 6-8 feet. To close, will maintain a humid area within a large circumference in relationship to the building.
The root system is high on those particular shrubs, lateral pressure is increased as they get higher.. Not significantly, as a deep rooted tree or shrub. Same problem as yours done last year to elevate pressure and water infiltration on a extensive home. Lost photos to explain more. Its close to your pictures and problem. Shrubs will keep that wall damp. If zoned for snow the problem intensifies. Just trying to help. I know I am new. The home was like yours and picture it with as many shrubs. Lost photos of total project. 2009. Look at soil in relationship to the Indian stone. I excavated 8 inches to leave a 4 inch exposure. Sorry for edits. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 Last edited by ryoung7; 10/5/11 at 10:37 PM.. |
Great Job Joe, that is exactly the type of thing I love to find.
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
That is not something you really want to find but of course when its there, its there. Weep holes would not have saved that one. Seller will probably have to get an attorney before it's over.
| Orange County Home Inspections | whandley | California Inspectors | 12 | 5/18/11 6:35 AM |
| Florida Licensing Bill - Action Soon | jburkeson1 | Legislation, Licensing & Legal Issues for Inspectors | 250 | 7/1/10 4:50 PM |
| Coeur d'Alene, ID Home Inspectors | rspriggs | Miscellaneous Discussion for Inspectors | 12 | 1/8/09 5:16 PM |
