Last inspection was a 1900 brick home converted to a four unit apartment. Two course brick, two story, brick foundation at the corner in question. Photo of entrance to Unit D is the south wall (as reference). Notice the cracking above the windows from eves to foundation. Photo showing basement foundation is the corner in question. Serious cracks on the outside, no visible signs of cracks on the inside. Main drain to sewer was added after the house was built as this is in rural Ohio so indoor plumbing came later. Wall with electrical panels (west wall) was starting to look like the south wall.
| Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Todd, is that a large support plate with thru-rod/bolt over the window in picture 2?
You bet. And the defects looked like they had been that way for some time. I did recommend an evaluation by an SE
Good. Looks like the other end of that rod was in your seperate post. http://www.nachi.org/forum/f23/brick...ntinued-49617/
Looks to be sinking to the right of the small porch, and pulling the wall down and out.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Todd:
Could the building be balloon frame construction with brick veneer. I'm not seeing any header bricks, that normally indicate solid brick construction. Also The support plate over the window and what looks like the other end would have me believe an SE has already done something. Do the owners have info to share? Cheers Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
Owner was with me the whole time, playing down the structure, wants to replace the foundation under the corner. The inspection was paid for by the bank because the owner wants to borrow against the structure to complete the interior renovations. Only two of the four units are finished.
Interior walls were solid brick with plaster over them for paint. |
| Why do brick spall? | mbryan | Exterior Inspections | 68 | 9/1/11 10:10 PM |
| Learn the Differences: Site-Built, Modular, Manufactured/Mobile Homes | jsieg | General Inspection Discussion | 10 | 12/22/07 11:20 PM |
| Toxic Gas in Mobile Homes | jbushart | Miscellaneous Discussion for Inspectors | 0 | 11/12/07 8:31 PM |
| Grab Your Checkbooks - For sale: 2 million empty homes | jburkeson1 | Miscellaneous Discussion for Inspectors | 2 | 10/26/07 7:22 PM |
| Massachusetts Clay Brick Education | ajalowsky | Miscellaneous Discussion for Inspectors | 2 | 2/22/06 6:34 PM |
