Old 2/1/11, 9:02 PM
Joseph Tribuzio's Avatar
Joseph Tribuzio Joseph Tribuzio is offline
Default Brick shim for concrete pier
Is it really acceptable to use bricks as shims for a concrete pier supporting a metal beam in a crawlspace? sorry for the fussy pic - spider webs-
btw i want to suggest that additional beam supports are installed.
Joseph Tribuzio 708 453 8447
Tribuzio Home Inspection Services
CHICAGOLAND, ILLINOIS
www.thishomeinspector.com
ID# NACHI07062507
IL Lic#450.003128
Radon lic# RNIT2008216
Home Inspector Pro Software
HIP Web Hosting
Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/1/11, 9:07 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Default Re: Brick shim for concrete pier
I would say no on the bricks, especially the direction they are laying. And, are you qualified to make the call on adding the additional beams or should you recommend a specialist?
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 2/1/11, 9:13 PM
Well hard to see in the pic, but they line up perfect with the beam. No, your right, and thanks, I am not a structural engineer so i will refrain from recommending additional support
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 2/1/11, 9:19 PM
Here is my DESIRED comment: A concrete pier supporting the metal beam is using bricks as a shim- Consult a Structural engineer to evaluate if this is acceptable. see pics
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 2/1/11, 9:32 PM
Now i'm not so sure why it would be so bad, considering the crawlspace floor is concrete, the pier is concrete - there wont be movement, ( unless Chicago gets more earthquakes)
Acceptable material i am seeing referenced often is steel - wood is not good, but brick seems ok - not commenting on local building code.
I GUESS I'M ASKING MY SELF ( AND MY FELLOW INSPECTORS HERE ) WHY THIS SHOULD BE CONSIDERED A SIGNIFICANT DEFECT?
OR can i consider the brick to be an extension of the pier?
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 2/2/11, 12:15 PM
Randy L. Mayo, PE's Avatar
Randy L. Mayo, PE Randy L. Mayo, PE is offline
Joseph
From an engineering standpoint brick has a compressive strength in the range of 3000psi to 10000psi. So brick has the strength to support that beam if used properly. The problem with dry stacked (no mortar) brick supports is the brittle nature of brick and point loading. Without mortar to help distribute the load evenly over rough surfaces the load on the brick is concentrated on the point where it actually touches the beam and the concrete pier. This issue of only a few small points on the brick carrying the load could crack or crush the brick. In a situation like this I also look at the bigger picture and ask myself two questions.
  • How long has it been in place?
  • What happens if it fails?
If failure could result in injury or death I would recommend fixing the problem ASAP regardless of how long the situation has existed. If failure would result in only some degree of physical damage to the house I would take into account how long the brick has been in place and explain what could happen if failure occurred and let the buyer decide.
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 2/2/11, 12:28 PM
Joe Funderburk, CMI's Avatar
The brick has the holes horizontal and the load bearing design of a hollow brick is with the holes vertical. That "shim" is incorrect.
Here is what I require as a building official in my jurisdiction.
http://www.cloversc.info/Forms/Dev_S...rpretation.pdf
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 2/2/11, 3:34 PM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is online now
No no.
That is a clay brick and will degrade because it will accept water and swell and spall.
I would like to see a saddle cupping the 2/8 joist.
Fastest and cheapest fix.Ceder would work for me or teak shim.
If it is cement or block it will transfer moisture to the wood.
Old 2/2/11, 3:36 PM
Mr.Funderburk.
You to. To many members looking through the glass window at the InterNASHI members inside.
Hope you become a member in good standing soon.
Old 2/2/11, 4:16 PM
Ah, thank you guys. Plus There is an additional consideration - the beam is not continuous- its actually two beams terminating and resting on those bricks. So even worse.
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 2/2/11, 4:32 PM
so heres some abuguity because contained in that code #4 it reads:
"4. All shims are limited to 4” in height, if over 4” masonry should be extended on pier. "
So am i partially right that it isn't to be considered a shim but an extension?
Now all i can say with certainty is that the orientation of the bricks are not correct with respect to the load design.
I understand the brick can swell and spall, but this was a dry concrete floor crawlspace in a topographically high village. hrmmm
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 2/2/11, 4:54 PM
1: Loads are not to be transferred onto brick in that fashion.
They are not engineered to carry load like that.
2: that high is 31/2
I am a mason.
.That is a Metric Modular
Wrong with that being used as shim.
http://www.capbrick.com/bricksiz.htm
Old 2/2/11, 5:00 PM
I am a mason.
AWESOME LINK... thank you ! best answer i've got yet , very much appreciated
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 2/2/11, 5:39 PM
I don't think my documentation is ambiguous. If the gap between the pier and the beam is > 4" the pier should be extended with another permanent course of masonry (not a loose brick).
That's not a code, but my requirement as a building official.
Joe Funderburk
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/2/11, 6:11 PM
Thank you.
You have also made me fell good by saying so.
Why do brick spall? mbryan Exterior Inspections 68 9/1/11 10:10 PM
Crumbling Bricks bthompson1 Exterior Inspections 32 2/3/11 8:27 PM
Brick Support Pier Skip Erwin Structural Inspections 19 9/26/07 3:58 PM
Brick-Veneer Inspection Guide jbowman Exterior Inspections 12 1/8/07 9:20 AM
Massachusetts Clay Brick Education ajalowsky Miscellaneous Discussion for Inspectors 2 2/22/06 6:34 PM
