Ed Siu is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi ,
I've just finished doing a structural walk through of our new house in Toronto canada, and I've never seen anything like this before, but the super insisted this is okay.. Using bricks and steel plates to shim up steel supports. (see pics). the plates were all loose, I can pull and push plates around with little effort. The super told me that they'll stuff concrete in there and finish it off nicely once they're done. I am just not getting a easy feeling about it as it can shift over time. Also, how much honeycombing is acceptable in concrete foundation? I found this area pretty bad, but again, the super says its fine because the city inspector wouldn't have signed off on it if it wasn't.. see last pic. your expert opinions is appreciated. ![]() ![]() ![]()
john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
sheesh, i don`t like it, wouldn`t buy it but thats Bubba-Gump.
city inspectors not always right, especially when it comes to basements/waterproofing/foundation work...causes/remedies of problems etc. |
My advice, would be to get rid of the Super.
Let me know if you really need help. I had to laugh at those pictures. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Yes, that does not look good. I would have an outside professional come in and give you a written, signed, objective, opinion and present that to the super or seller. I just don't trust the support system in place judging just by pics.
Totally unacceptable! You've got to be kidding!
Take those photos to your building department and ask for the inspector who signed off on this mess. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Maybe it was the same guy that poured the foundation!!! LOL Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Were those welds? Looked like bubble gum. . .
Thanks for all your input guys, I'm definitely taking this up with the city inspector.. those individual shims are not welded together, just jamed in place.. but the other end of the IBEAM is welded to another IBEAM, so it's is only the wall end that is left unsupported..
I also did see any anchors from the frames that sit ontop of the IBEAM, they are just nails bent over to clamp the IBEAM.. This is going to be my house! it's in a urban subdivision... |
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
| Why do brick spall? | mbryan | Exterior Inspections | 68 | 9/1/11 10:10 PM |
| Crumbling Bricks | bthompson1 | Exterior Inspections | 32 | 2/3/11 8:27 PM |
| Slate Main Beam Shims | jevans | Structural Inspections | 2 | 2/27/08 5:50 PM |
| Brick-Veneer Inspection Guide | jbowman | Exterior Inspections | 12 | 1/8/07 9:20 AM |
| Massachusetts Clay Brick Education | ajalowsky | Miscellaneous Discussion for Inspectors | 2 | 2/22/06 6:34 PM |
