Old 4/2/06, 10:00 PM
sspradling sspradling is offline
Please Note: sspradling is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Bulge in stucco at 2nd story
My saturday inspection was on a 50+ year old stucco 2 story. On one side, right about where the floor of the 2nd floor would be, there was a visible outward bulge in the surface of the wall. I looked at several of the neighbor's houses, and the bulge was common to 3 of 4, on both sides of the street. There were no signs of anything unusual on the inside of the house. Any ideas on what the cause could be? Thanks for the help and advice.
Stu.
PS-Can someone explain to me how to resize my photos for the "new" message board?
Old 4/2/06, 11:06 PM
bchew bchew is offline
Please Note: bchew is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Bulge in stucco at 2nd story
Was there a horizontal control joint in the stucco near the rim joist between the first and second floors? If there was not, and the joists shrank a bit as the lumber dried out, it could cause the stucco to bulge out in this area.
Old 4/3/06, 2:04 AM
Russel Ray's Avatar
Cripple wall.
Very common for two-story stucco houses around here. Ugly but no structural concerns.
Old 4/3/06, 5:38 PM
rray,
What do you mean by cripple wall? This was on a gable end of the house, if this makes any difference.
Stu
Old 4/3/06, 7:43 PM
Sounds like it was the same Framing Contractor that can't line up the box header of the second floor with the wall below. ha. ha.
Marcel
Old 4/3/06, 7:48 PM
David P. Valley's Avatar
Originally Posted by sspradling
rray,
This is a Cripple wall.
Attachment 2582
I've never heard of a cripple wall on 2nd floor.
Old 4/3/06, 7:53 PM
rwand1 rwand1 is offline
Sounds like corrosion or pulling away of the screening under the scratch coats.
Old 4/3/06, 7:54 PM
Wasn't this subject of the crippled horse wall a subject on this forum before??
Marcel
Old 4/3/06, 7:58 PM
Marcel
Yup, here it is...
Attachment 2583
Old 4/3/06, 11:08 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
Marcel
YUP. one of my favorites. i think we collectively decided to call them "cripple kneed pony" walls, or a crippled knee from tripping over a pony wall, or something. i hurt a rib laughing during that one.
Russel Ray's Avatar
rray,
A cripple wall is a wall that is less than full story height. Here in earthquake country, we also build them between the floors of a building and use that space to run electric wires, air ducts, etc. The ceiling of the first floor is not the actual floor of the second floor; there is a space between the first floor ceiling and second floor floor, usually 18-24 inches high. When framed a certain way, a cripple wall is created. Unfortunately, today’s construction is so shoddy that the cripple walls are not framed properly and/or the stucco guys don’t know what to do when they get to that point.
Cripple walls are quite common in earthquake country between all floors.
In South Texas, we never used them because the land was flat and there were no earthquakes. There still is a space between the two floors. It’s just that you won’t see a break between the two floors from the exterior. All the breaks are done in the interior using framing, drywall, etc.
What is described in your post is a second-story cripple wall.
Remember that the largest earthquake in the history of the United States was that New Madrid earthquake in Missouri in 1811-1812, so I would not think it unusual to find second-story cripple walls in Missouri.
http://asms.k12.ar.us/armem/richards/index.htm
Here’s a pretty good site on cripple walls:
http://www.abag.ca.gov/bayarea/eqmap...ch2/sld017.htm
Old 4/4/06, 1:35 AM
eschwartz's Avatar
eschwartz eschwartz is offline
Getting off the subject: A bit further North from RRay, a common 2nd floor addition strategy is to build one o them horsey walls on top of original 1st story, run TGI joists the entire width of the house and build the 2nd floor on top. The 1'-18" between 1st floor ceiling and 2nd floor subfloor allows for easy installation of new ductwork, plumbing, electrical etc as RRAy says. Makes the addition a little top-heavy, but its quick and doesn't require the finesse such an addition would otherwise require. This must be happening in other parts of the country, eh?
Ed
Old 4/4/06, 9:18 AM
Russel Ray's Avatar
Sorry I wasn't able to finish my post properly last night. I had margarita-induced employees bothering me about the NCAA basketball game.
What is shown in David's picture is not a cripple wall in the classic sense of the term. Ideally, a cripple wall is of the same height/width/materials/etc. throughout its run, and, hopefully, one has the same type of cripple walls on all sides of the structure. That in David's picture is a combination of block and stick, which creates many areas of different engineering strength whereas a classic cripple wall would carry forces evenly throughout its run. Block will carry/support forces differently from wood.
Our older houses here don't have cripple walls even with raised foundations. And the newer houses are built on slabs with cripple walls only at the first floor/second floor/third floor/etc. junctions.
What is shown in David's picture is what I would call foundation framing on a hillside home. And if one looks at the left side of the picture, it does look like the ground slopes from back to front. Additionally, the best cripple wall would never cut a member to make room for the anchor bolt, as has been done to that second vertical member from the front. I doubt that that cut was engineered; probably simply done by the builders on site because the stupid anchor bolt got in the way. Darn.
Old 4/4/06, 9:44 AM
Thanks for all the responses. Now I know what a cripple wall is. I don't think that is what's causing the bulge, I can't seem to envision anything other than full length studs, platform frame construction. There were almost no cracks in the top coat, so it must have been there for quite a while. I know the owners, and they haven't made any repairs in 14 years, so it must be stable. I guess I'll wait for an earthquake to get my answer. The house in question is in Kansas City, a little outside of my regular service area, not as close to New Madrid as my town. Thanks to all that weighed in on this question. This board is always a terrific source of information.
Stu
Old 4/4/06, 10:11 AM
Russel Ray's Avatar
The title of your thread, "Bulge in stucco at 2nd story" said it all for me. I never note cripple wall bulges in my report, which, perhaps, I should do since I occasionally get a question at the time of the inspection concerning the "bulge in the stucco at the second story."
"Just a cripple wall, ma'am, just a cripple wall."
Need to ID type of stucco cdewitt Exterior Inspections 20 12/4/06 10:39 PM
Stucco course badair Inspection Education & Training 2 11/21/06 5:51 PM
Wisconsin stucco problem dnice Exterior Inspections 6 10/17/06 8:03 AM
Stucco and Building Wrap eyerise Exterior Inspections 5 6/29/06 8:35 AM
Stucco Inspection dlee2 General Inspection Discussion 7 4/3/06 8:17 PM
