Southern Calif. home built 2005 on a slab foundations.
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks like an unbonded Post tension cable, severed.
Jeff Pope probably knows more. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
That is a failed tendon, which is a structural deficiency. For a house buit in 2005, the builder is responsible for repair, unless the owner severed the cable.
As Marcel stated, this is an "unbonded" type cable, which means that it is always live. When they break/fail, they can cause property damage and/or personal injury. If the occupants were home when this failed, they would have known something happened. The failure will shake the entire house. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 4/18/10 at 5:36 PM.. |
That is a great Picture
usually happens when the framers drill holes to install wedge anchors. As a superintendent I saw this all the time. Those cables are pulled to 15k psi or more. When they let go they can shoot out completly or it can be fairly quiet and unnoticeable, just a slight pop in the side of the slab.
Actually, in PT slabs, the cables are normally stressed between 2250 and 2750 psi. . .
PT slabs are neat.... especially when they tile the slab right away, while it's still green and under tension....ugh. Even tile showers become kinda neat when installed on the PT slab floor. I think I can write a report on a newer home before I walk in the home for some of the defects in there. I say "neat" because it gives me something to look at
Slip sheets for the tile...."we don't need 'em!!!" Would add at least a hundred bucks to the cost of a new home... Construct the mop/membrane system for the stall shower and drypack floor within a couple weeks after the slab is poured.... "why not?" I looked at 3 in the last couple days with tile at entry/halls and a tiled floor with PT slabs..... all were nicely cracked on floor tiles. Corners of tiled showers??? cracked. |
Interesting. A PT slab is something I have yet to see in the Carolinas.
We don't have them fancy houses here in the hills of TN
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
I love any foundation that I doesnt have a crawl space.
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
| Foundation Issue without Physical Evidence? | Kim Everhart | Structural Inspections | 13 | 10/8/07 7:29 PM |
| Nachi, The Foundation and Estill County Ky | psabados | Charitable Organizations | 2 | 11/14/06 5:53 AM |
| Draw inspection " Foundation electrical" question | lgongre | Electrical Inspections | 8 | 10/29/06 1:26 PM |
