rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Not from an inspection. It's my brother-in-laws home.
This is in the garage. Upper chord of truss seemed charred. Was not wet. Thought it might have been fire damage, but the lower chord was not damaged. No apparent problems on the roof above. Insects? Lightning? Leak? Other? |
| Find an InterNACHI certified Hawaii Home Inspector (and anywhere else in North America) |
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
That looks like water related damage.
I was doing an inspection with a pest inspector one time and they had a shed that looked like it had had a fire on the inside (although it didn't really seem like there had been a fire - it was years ago, so memory is a little fuzzy). He said it was fungus damage. |
How old is the home?
What type of roofing? Is that the original roofing, or has it been replaced? |
Something's been repaired on the roof covering above....see the 4 strange nails in the 3rd photo. I'd surmise a small lightning strike that breached the shingles and water intruded for some period of time (hours, days, weeks) before repairs were made to the shingles and nothing was done to the framing.
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
Looks like good old rot to me. If there is a large amount of resins in the wood, they will often turn black like that from rot and staining. If you took a UV light up there, you will probably see that the wood has a lot of sap on the surface. The sugars break down and turn black. Often, you will also get mold growth on areas where the sap sugars have broken down. Take a UV light to it and if you see a slight yellow to green glow, you will have have a good indication.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Looks like water damage, Burn would look a little different , One question is the wood charred on the under side by the edge? I think there be more of a blister pattern if it was a lighten strike . Also the trail would be different.
Btw was there any soot?
Dryrot (Brown rot).
![]() Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
| What caused this | gporter | Interior Inspections | 10 | 6/22/06 2:27 AM |
