Okay, I'm at a loss for ideas on wording for my report... any thoughts are appreciated.
1900 home, chains in attic are above kitchen area (single story). No indication of any issue in kitchen ceiling or walls. Roof plane is off a small amount, mostly from bad repairs over the years. The roof is getting a complete tearoff when the rain stops (next week?). What you see in the pics, is all I know. Chose not to enter that half of the attic. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
| Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Will not say my first thought but could they have been planning to put some equipment up there?
I notice the turnbuckles.Maybe they are holding a platform. Curious why you did not go look since it is obviously safe or they could not have attached the chains. |
The only idea I have is more than one joist is compromised, and I wasn't going to test it. Add to it the condition of the roof sheathing and bad repairs done to it, I wasn't going to risk my personal safety. Client had no issue with my self imposed limitation. Even so, I keep stumbling on the wording for my report. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Don't you know anything? Those are used to hold the engine. You cook on the manifold when you dont have a stove....
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Okay..
So far we have the following suggestions: 1) Hanging bed 2) Engine hoist/BBQ 3) ? Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Jeff those chains look new with the white ID tags pretty white looking son how old is that ceiling would you say?
The only reason I can think of to support joists would be they saw damage occurring below somehow. The insulation is new from what I can tell considering the kitchen looks older or slightly outdated. Upon inspecting attic support chains were being used attached to joists supporting the ceiling. I recommend a framing carpenter determine if joists are in need of repair as safety concerns prevented further investigation during inspection. The insulation will need to be displaced to view fully. |
Prolly was a Den of Inequity before they decided to blow some Insulation in to cover the Dance floor--- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Unsure on age. These old farmhouses get added onto and remodeled everytime a couple more kids come into the world. The current owner has lived there about 9 years, and has "upgraded" many things, such as wiring for his man cave and two home offices. Still on 100 amp service! I assumed the current owner added the chains, but could find no definative reason for them. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
That looks like my old S&M playground!
Always erks me to see roof framing like that.. bare minimum stuff... scrapping in some ridge blocks (never mind a ridge) and ties woulda blown the budget outta the water there. A lot of the time, I see older homes where the framers did a BETTER job.. not there though.
. anyhoo, was the kitchen always that OPEN? Maybe even some short spans landed over a wall... then removed and braced w/chains.. Ventilation looks minimal as well. Excess moisture build up, then sag? Couple stabs there. Either way, the chains are doing *something*.. and I would mention as such. |
The fat inspector didn't walk the attic, can't you see how restricted (inaccessible) the space is ?? Too late for questions now Mr. Fat Inspector.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
Original plaster has been repaired with new drywall. The extra weight required it to be chained in the area. Most homes of that period had 2x4 ceiling and roof joists and would not hold the weight for the span of that size kitchen. The way to tell is to remove a small section of drywall and look for plaster. Don't forget the fact that there is extra weight to the 8-10 inches of insulation added also.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
| Roof decking condensation. | Homewood | Interior Inspections | 15 | 3/5/10 11:00 AM |
| Mold question? | ccurrins | Interior Inspections | 35 | 1/23/09 11:55 AM |
| Truss Uplift | rcooke | Canadian Inspectors | 5 | 2/26/08 7:43 PM |
| Spray Foam to the Rescue ? | mcyr | Structural Inspections | 3 | 3/27/07 7:29 PM |
