6 year old log home, stone chimney
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Did he install back rod and sealant recessed also?? Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Come on Marcel...I've built enough log homes (3) to know that he installed the chimney....and hurried up and installed the logs while the mortar was wet to make that impression....then moved the entire wall 3 inches to get the desired effect.
you guy's are right, the wall is the thing that moved.
It looks like more but the log wall actually shrunk 1 inch vertical and 1 inch horizontal. Common problem with log homes. The chimney did not pull away from the roof at the top. I just reported the gap and recommended further evaluation. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
I guess the mason does not know that log homes settle.
Larry |
"Ouch" LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I did, the client was owner/builder.
| Electrical Inspection Training for Home Inspectors | jtedesco1 | Inspection Education & Training | 6 | 4/27/06 11:43 PM |
