Old 5/4/10, 7:29 PM
tirwin tirwin is offline
Default Chimney
Why would this chimney have a crack straight up the middle?
Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/4/10, 8:15 PM
Banned
Default Re: Chimney
Does this flue serve a wood burning appliance?
If so and the chinney was not built using the best practices, could be caused by a chimney fire expanding the clay tiles which pushed against the block creating the crack.
The expansive forces of nature by heat expansion or when water freezes are very powerful!
Old 5/4/10, 8:35 PM
Tim Spargo's Avatar
Default Re: Chimney
What were the soils or visible support under the chimney? Their condition? Any signs of rotation away from structure....?
You're in a place that freezes very nicely too, I think.
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 5/4/10, 11:14 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Chimney
Just a guess without a pic of the top of the chimney. Moisture infiltration at the chimney cap and no rain cap have caused the rebar in the block to rust and swell causing a crack which allows more moisture and so on. My disclaimer on this is that we only have three chimneys here.
www.MauiHomeInspections.com
Old 5/4/10, 11:16 PM
Randy L. Mayo, PE's Avatar
Randy L. Mayo, PE Randy L. Mayo, PE is offline
Default Re: Chimney
Thomas
It appears to be an expansion crack due to excessive heat. I would expect any water that entered would wind up at the bottom before it froze. Excessive heat would expand the entire chimney causing the expansion crack to go all the way up.
Old 5/5/10, 9:42 AM
Default Re: Chimney
It does have a wood stove.
Old 5/5/10, 9:43 AM
Default Re: Chimney
No signs of rotation and it sits on a strong footing.
Old 5/5/10, 9:47 AM
Default Re: Chimney
I recommended them to call a chimney sweep. thank you, every one.
Old 5/7/10, 12:42 PM
Default Re: Chimney
Brian nailed it......improperly built chimney. GC warranted.
What's Inside A Chimney mcyr Inspecting HVAC Systems 14 9/17/08 6:11 PM
Chemical Chimney cleaners do not work rcooke Canadian Inspectors 6 2/12/08 12:02 AM
Difficult Chimneys thance Inspecting HVAC Systems 2 1/29/08 8:16 PM
Floating Chimney Syndrome mcyr General Inspection Discussion 8 7/24/07 11:49 PM
Fireplace Enclosure jpope Interior Inspections 19 10/25/06 5:08 PM
