Chimney on rear of 3yr old house with deck wrapped around chimney.
Small cracks above the top of the gas grill... Larger cracks behind the gas grill.... The crack does not extend lower than about 4 feet above the ground. No rain cap on chimney.... Freeze expansion? B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Any separation from the house at all?
Small or large gaps? Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
No other issues are present, just this seperation that is not near the base/footer.
It looks somewhat like some heat cracking I've seen on other chimneys. What does the chimney service?
I have seen chimneys crack like that due to severe creosote based chimney fires but the cracks appear farther up the actual chimney not behind the fireplace (if it is a fireplace). Wonder if something venting into the chimney was overfired and the temps rose quickly, causing thermal shock? This is the phenomenon that causes cracking in chimney fires. The flue gases were chugging along at 300-500 or so degrees F, then the chimney fire starts and temps rise within 2-3-4 minutes to 1200+ degrees....that's a shock to the chimney as the tiles expand much quicker than the unit masonry does.....pressure and the crack occurs. Last edited by Brian A. MacNeish; 1/31/08 at 12:11 AM.. |
Brian provided one very good theory.
Unless other evidence is present, as in the crack express' itself in the firebox (CSIA Level II), just monitor for further movement. Book ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 9:16 PM |
| Floating Chimney Syndrome | mcyr | General Inspection Discussion | 8 | 7/25/07 12:49 AM |
| Fireplace Enclosure | jpope | Interior Inspections | 19 | 10/25/06 6:08 PM |
| Chimney problems | mroe | Inspecting HVAC Systems | 13 | 3/30/06 10:14 PM |
