Top three mortar joints deteriorated, the rest OK.
Owner stated that they remodeled the fireplace face this summer after deciding to put it on the market. My theory is that the chimney was originally too low and didn't draw well, so there was some smoke damage on the face of the old fireplace and mantle. At some point one cold winter they had a new fireplace installed and the installer said "hey, chimney's too low, that's why it smokes!" so they extended the chimney. During the winter. The mortar froze before it cured fully and so was weak and subject to accelerated weathering. That's my theory, anyway. Thought I'd add the bighorn lambes and ewes. They ran accross the road in front of me on the way there. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Hard to say from Tucson. |
Yep, raked and repointed.
Good catch on a snowy roof. Be careful and by all means have fun.
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Kent,
While your hypothesis may be correct but without factual documentation. Who know? If you are not trained in chimney evaluation I would defer to an expert, as I'm sure you did. The majority of masonry chimneys I see that have deterioration have it occurring at the uppermost portion of the flue, crown, and cap configuration as in your example of the upper three courses. Most are related to moisture intrusion from a failed crown or cap and possible design anomalies. Further information may be found here: http://www.csia.org/homeowners/water.htm ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Kenton, I see you did a favor to your client and shoveled his porch for him.
That was pretty nice of you. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Build them right and you won't have this problem.
I've only seen one. http://www.1stchoicechimney.com/documents/Tops-to-Last-a-Lifetime.pdf ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
I'm the guy behind the camera, Marcel. The client breaks trail and does the shoveling. I'm the guy who takes pictures and tells the shoveler "you missed a spot"
I told them it appeared to be freeze damage, but my recommendation was for a qualified masonry contractor to rake the joints and re-tuck. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
| Masonry mortar types | mcyr | Structural Inspections | 11 | 11/11/07 11:36 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Floating Chimney Syndrome | mcyr | General Inspection Discussion | 8 | 7/25/07 12:49 AM |
| Fireplace Enclosure | jpope | Interior Inspections | 19 | 10/25/06 6:08 PM |
| Historic Masonry Re-pointing: Repair or Ruination? | mbryan | Exterior Inspections | 4 | 2/21/06 10:49 PM |
