| Structural Contains discussions about the structural portion of a home inspection. This includes foundations, framing, et cetera. |
Collar Ties need to be on all rafter correct....should i defer this to a framing contractor?
| Find an InterNACHI certified South Dakota Home Inspector (and anywhere else in North America) |
Every third rafter.
If it's a relatively new home, I would refer it to a contractor. Absolutely.
If it's very old and no sag is noted, then I'd just note that it doesn't meet today's commonly accepted standards but may have been appropriate at the time of construction. Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
This home was completed today so yes it is new and i am recommending a contractor.
R802.3.1 Collar ties or ridge straps to resist wind uplift shall be
connected in the upper third of the attic space in accordance with Table R602.3(1). Collar ties shall be a minimum of 1-inch by 4-inch (25 mm by 102 mm) (nominal), spaced not more than 4 feet (1219 mm) on center. Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Thanks Joe.
Curious,............. what is going on with the 2x4 blocks tied toward the bottom of the rafter?
Are those rafter cantilevered on the ceiling joist? Jeff |
Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder Ouellet Associaties Inc. http://www.oaconstruction.com/ |
Some jurisdictions don't require collar ties.
Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) EXPERT WITNESS Director of Green Building Director for International Development (303) 717-8940 (303) 258-8289 |
| Collar Ties | rgreene | Exterior | 3 | 12/13/08 9:33 PM |
| Czech collar ties | srowe | Exterior | 4 | 12/8/08 2:54 PM |
| How high do collar ties need to be? | Nathan W. Swilling | Structural | 12 | 1/9/08 12:41 AM |
| Collar Ties | rkoehler | Interior | 11 | 5/10/06 8:01 AM |
| Collar Ties--When Required? | jfunderburk | Structural | 7 | 5/6/06 2:49 PM |
