jchamp is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ok, what is the rule for non disturbed soil around the columns and piers in crawl spaces. See attached pictures. Obviously this needs attention from a foundation expert, but just trying to figure out the basic rule.
Thanks |
This response from Kenton Shepard on a similar thread.
"The supporting soil is called the "Cone of Compression" and radiates out at a 45 degree angle from the bottom edges of the foundation. If they interrupt the cone of compression they have compromised the ability of the soil to carry the weight of the structure above and the area compromised will need to be stabilized. The cure should be spec'd by a structural engineer." Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Skip Erwin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ditto! Structural Engineer all over this one.
Looks like someone was digging after the foundation was finished. Reminds me of the 'Big Dig" in Boston. |
The "Cone Of Compression" can be violated, but ONLY with specific engineering which has taken the soil characteristics into account. From the looks of things, I doubt that such engineering has taken place. The main thing saving a collapse is that the soil appears to have a high clay content, which is one of the cases when the "Cone" can be violated, but again, only with engineering and maybe soil testing.
tneyedli1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Strongly urged to have structural/geotech survey performed. T.Neyedli www.alphahomeinspections.ca |
| Do you charge extra for crawl spaces | jfunderburk | Miscellaneous Discussion for Inspectors | 56 | 10/8/09 2:29 PM |
| insulation in crawl spaces | etrippe | General Inspection Discussion | 15 | 5/23/07 1:09 PM |
| Steel post question | sspradling | Structural Inspections | 42 | 3/2/07 8:59 PM |
| Tight Crawl spaces | bkelly1 | Miscellaneous Discussion for Inspectors | 17 | 2/15/06 9:37 PM |
