Old 10/13/09, 9:25 PM
Bryce W. Jeffrey Bryce W. Jeffrey is offline
Default Compression Blocks Required?
Does this application of Engineered Floor Joist with aspenite web require compression blocks at the ends?
Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America)
Old 10/13/09, 9:30 PM
Default Re: Compression Blocks Required?
Typically squash blocks are required where a load bearing was is above...
Larry Kage, CMI
231 929 3525
Old 10/13/09, 9:34 PM
More info:
http://www.apa-europe.org/Languages/English/PDF/12.pdf
Larry Kage, CMI
231 929 3525
Old 10/13/09, 10:38 PM
Dale Duffy's Avatar
Hi Bryce,
From here it doesn't even look like the bottom of the engineered joist is even touching the Iron..but if it is I wouldn't think so if the correct Joist Hangers were used, which does not look to be the case either.
Old 10/14/09, 11:49 AM
Wow - looks like those joists are bring held only by a couple of 8d nail at the top of the joist hangers. Not good!
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 10/14/09, 12:31 PM
Michael R. Boyett's Avatar
Originally Posted by fnewman View Post
wow - looks like those joists are bring held only by a couple of 8d nail at the top of the joist hangers. Not good!
It's probably a Top Flange Hanger and the nails are not visible.
Old 10/14/09, 1:04 PM
Mark S. Tyson Mark S. Tyson is offline
the only way too make a determination is by reviewing the engineered truss drawings which would be included with the original construction documents and is required to list the attachments for each member. with that said typically minimum bearing for a joist would be 1.5" over wood or metal and 3" over masonry or by an approved joist hanger.
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Old 10/14/09, 2:52 PM
Marcel Gratton's Avatar
See page 81 at: http://www.nascor.ca/literature/C-2007USA.pdf
On The Level Inspection
Gatineau, Québec
Old 10/15/09, 3:42 PM
Unmoderated Guest
I think the questioner is referring to "web stiffeners", and whether they are required or not will be found in the joist manufacturer's literature. My guess is, probably not.
Old 10/15/09, 4:10 PM
If that is what he is after, it doesn't look like they are needed there.
Click:
http://www.apawood.org/level_c.cfm?c...ub_joi_libmain
...and scroll down to:
Builder Tips: I-Joist Web Stiffeners
Larry Kage, CMI
231 929 3525
Old 10/15/09, 5:29 PM
Those are top mount hangers which do not require compression blocks.....also these type of hangers are nailed from the top therefore they are most likely covered by the sheathing substrate.......... no comment on what nails were used being that pictures do not clearly show what they are.
Packing out the I-joist and/or I beam is overkill.
Jeff
Old 10/15/09, 7:31 PM
Thanks guys. This is what I like about this site.
Regards
Bryce Jeffey
Liability question jcahill Legislation, Licensing & Legal Issues for Inspectors 30 8/24/08 4:10 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
Emergency Lighting (commercial) mcyr Electrical Inspections 24 6/10/06 10:06 AM
