Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Any ideas what may have cause this sheer right through the ledge of a garage window? No foundation cracks or any other sign of settlement.
Erol,
I was looking at the joints and caulking around it and from what I can see there was no unevenness to them indicating previous movement. It is hard to tell from the picture but even the caulk immediately above the dropped section of ledge appears to be same width as to the left of it. The caulking also does not appear to be new. What did it look like on the underside of the ledge? Was the mortar even across, new, old, looked repaired, missing, crumbled. Any signs of damage to the window, sashes, etc.? Is it possible it was cracked either during build, or possible rehab work, and never repaired, or so old a crack its cause is not discernible due to other potential changes (i.e. window repairs, mortar repairs, etc.)? Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
Thanks, Emmanuel. No I did not look under the broken slab.
In any case, it's cosmetic, not structural, in nature. It is curious that it can be dsiplaced vertically so noticeably, yet everything else around it seems to be in good condition. My guess is that it was indeed cracked during construction, and they just said "what the heck, it's only a garage", and left it that way.
Pre-cast or natural stone ledges like this may suffer undetected natural fault or pre-installation stress fracture, the mortar bed deteriorates or freeze thaw cycles occur over time and voila the fracture appears.
A "good historic mason" can fix this fairly easily using the original materials so aesthetics aren't lost. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Thanks guys for all the help.
The window unit (or actually original unit since it has been replaced) is bearing down on the hidden sill edge without good even support under the sill that rotated the sill to where part of the visible side (left) raised up. That age home has poor window headers that sag over time placing weight on the window unit. Still not a big concern. The crack was there when they replaced the window.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
| Post tension slab labeling | rchorey | Structural Inspections | 34 | 7/6/08 11:43 PM |
