bmahar is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi Everyone,
Is this condensation or a leak? New home 11th month home warenty inspection. Roof recnetly patched in a valley one rafter over. Drywall is very damp to wet below. Weather: Rain sometimes heavy last 24 hrs. Much mold growth in attic No other area has these water beads. Thanks for your oppinions and please give me a break this is my 1st post. |
I would lean towards condensation. Is there a heat source nearby? A bathroom exhaust vent? What's in the room below this area? Could be a leak though...is that an outside wall next to the wet area? What does the drip edge flashing look like in that area? What type of roofing? Asphalt shingles? What do they look like in that area?
This is next to an exterior wall over a bedroom with no nearby heat source nearby? Also inspected the eaves on the other side of the wall and saw no problems all all though even though there was no drip edge flashing. the eave hung out about 18" and was dry underneath.
Other notes:
Ashphalt shinges and a garage below the bedroom into which the leak made it at one time. |
Hi to all,
My guess is an active leak, and patch repairs are not going to help that sheathing it needs replacement. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
I would lean towards the condensation theory.
It could just be the picture, but it almost looks like sap. Did you feel it to be sure?
ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
because it's beaded up so much and not just soaked and drippy, my vote is condensation.
although, i'm curious to find out why it would be so concentrated in one area unless there's an exhaust vent nearby. the fact that a patch/repair was done nearby throws my opinion back to a leak. could be a combo of both. |
I too am voting "condensation," but the hanging drips do look like sap. Did you check for bathroom exhaust fans and, more importantly, ventilation in the area?
InterNACHI Vice President, InterNACHI Editor-in-Chief, co-founder CalNACHI Author of Manual For a Happy Home & Inspect & Protect |
Hi All,
Boy you guys are a lot of help?! You I did touch it, as I thought sap as well, but the drops were as wet as water could be. No vents were near here either. Here is another clue there were here looked like fly and some potato bugs but I am not sure what kind. It was strange to see them congregating in this area. Suggestions for verbage perhaps anyone? Thanks to all. |
Could the air be getting up past the attic door is it gasketed and insulated .
How about pot lights air from the home looks to me to be getting into the attic. Needs better ventilation both sofit and roof. Needs to stop home air getting into attic. Proper ventilation and this should not happen this bad Roy Cooke Well for your (Thanks for your oppinions and please give me a break this is my 1st post.) You have found out jus a little how great every one is at NACHI . Come on aboard love to help you . If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 Last edited by rcooke; 11/21/06 at 1:50 PM.. |
The reason I am thinking this may be just condensation is that below it is a wet wall and ceiling.
If no one else has anyone EVER seen known condensation that looks like this then I think I will rule this out. Keep then coming please, and thanks all. Bryan Mahar AVision Inspection Services Last edited by bmahar; 11/21/06 at 1:29 PM.. Reason: Typos |
http://www.ronhungarter.com/nw_scary_attic.html http://www.ronhungarter.com/siding.html http://www.ronhungarter.com/mold-attic.html Roy Cooke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
How was the attic ventilation? |
No attic vapor barrier only blown in insulation directly onto the sheetrock supported by rafters.
As for the Ventelation It did not look like enough. I am working on determinaing if indead this is a factor at this time. |
| Excessive AC Condensation Problem | kweiss | Inspecting HVAC Systems | 8 | 8/6/07 10:15 AM |
| condensation line | Rafael | Exterior Inspections | 8 | 8/20/06 2:41 PM |
| I have a leak in my ceiling. | The Machinist | Interior Inspections | 8 | 6/28/06 3:50 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 5:52 AM |
