Old 1/12/06, 9:20 PM
jburk2's Avatar
jburk2 jburk2 is offline
Default Crack in the wall
Found a crack in the wall today right underneath one of the downstairs windows. This window was in the walkout basement portion of the home and the window was about 3 1/2 - 4 feet high. The crack runs down from the bottom of the window to the floor and although noticable, wasn't very wide. No such cracks were found anywhere else in the home or on this particular wall. Here's the problem, there was a negative grade found in the landscape right outside of the window in question (underneath a deck/balcony) and the ground outside at the wall was very wet.
Waddaya think?
My first reaction, since this was the crack in the wall, was that it was minor. Then I started mulling it over and started to wonder.
I've never posted a picture before but I'll give it a shot.
Old 1/12/06, 9:57 PM
Brian E. Kelly's Avatar
Default Re: Crack in the wall
Wood frame house? Small crack in the drywall, probably nothing.
Old 1/12/06, 10:27 PM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
It looks so straight that it looks like where two pieces of drywall meet.
Observered (noticed) crack in wall board centered below xxxx window. monitor for further cracking and have repaired by a qualified licensed contractor.
Or something like that.
I don't think it's a big deal but you never know how the client will feel about it.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 1/12/06, 10:29 PM
jburk2's Avatar
Thanks Brian!
The home presented itself extremely well and it was the only crack in the entire home or on that particular wall. I was thinking that if there was a structural issue the wall in question would have presented much worse. I'll most likely recommend repair of the crack along with adjusting the exterior grade to allow for better runoff.
Old 1/12/06, 10:36 PM
jburk2's Avatar
Thanks Jason!
The client was concerned, but was very accepting of my response when I said that it was most likely not due to a foundation problem. She seemed fine with repairing the crack if it was only a minor issue. It's just that I got home and started to think about it and began to question it. I then decided to tap into that bottomless piece of infotania known as NACHI
You guys rock!
Old 1/12/06, 11:37 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
if that was the only crack, i'd spackel it an move on. if it were foundation problems you'd find more issues, ie; doors won't close, other cracks warped or cracked floors. any combo there in, but just one, not likely.
Old 1/13/06, 8:08 AM
rwand1 rwand1 is offline
Drywall crack. Wood frame houses do dry out and this is not settlement crack in my opinion. - Cosmetic.
Raymond Wand
Alton, ON
Old 1/13/06, 8:23 AM
John Onofrey's Avatar
John Onofrey John Onofrey is offline
Jay,I think it's awesome that you perform cosmetic repairs during your inspections!
Old 1/13/06, 9:06 AM
twheeler
Guest
Posts: n/a
I tend to agree with the above statements. Often times, there is a misplaced stud behind the drywall, and the joints are not properly screwed, when the stud dries, it twist, and the tape cracks leaving a small hairline crack.
Old 1/13/06, 3:30 PM
lewens's Avatar
lewens lewens is offline
Send a message via AIM to lewens
Please Note: lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
I bet the problem is that there is no tape on the joint and the crack will continue to reappear till it is properlytaped and mudded.
Larry
Old 1/13/06, 5:31 PM
Russel Ray's Avatar
Drywall seam crack.
Here's a discussion I wrote on cracks that I include in my Interactive Report System Version 2:
Old 1/13/06, 5:34 PM
Russel Ray's Avatar
Oooooops. I uploaded the backup copy, which has a couple of typos in it. Darn margaritas.
Old 1/14/06, 12:09 AM
Jay Moge's Avatar
yeah well i usualy cook a ham dinner to test that the stove and oven work properly too. anything to make 'em happy.
Old 1/14/06, 1:14 PM
Nothing, but a mere shrinkage crack. That's all. Don't worry about it, but note, to further monitor and evaluate further movement. See it all the time on Commercial jobs too, and shows that even on metal studs, these will occurr. Building a new building Residential or Commercial, humidity levels are hard to maintain, and when the regulated temperatures are maintained, and the struture dries out, you tend to see this type of shrinkage cracking. The tape and joint compound tend to let go under the drying process. Re-enforced tape for joint compunds (fiber mesh tape) seems to prevent alot of this from happening.
Jay; Hope you did not burn the stove while testing it out. Do you clean your mess when done? ha. ha.
Marcel
Old 1/14/06, 5:31 PM
Of course he cleans up--he has to test the dishwasher, doesn't he??
VIDEO--Bowed Basement Wall, Cracks etc john bubber Structural Inspections 75 7/21/08 5:25 PM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 10:48 AM
wall crack inside and out. rbracewell Structural Inspections 9 6/25/06 5:12 PM
Crack in the Wall , Too! srowe Structural Inspections 11 1/20/06 8:45 PM
