Old 1/21/11, 4:45 PM
David Liang David Liang is offline
Please Note: David Liang is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Crack in the Wood Beam
I was wondering if anyone can help me look at this wood beam to see if it need to be repaired. Thank you
This wood beam is located in the middle of the garage. There is a 2nd floor on top.
the majority of the crack appear only one side of the wood beam
Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/21/11, 4:47 PM
Default Re: Crack in the Wood Beam
It is simply wood checking and nothig to be concerned about.
Please reduce the size of your picture before posting it.
Larry Kage, CMI
231 929 3525
Old 1/21/11, 4:59 PM
Thanks for the quick reply Larry. I will go ahead and reduce the picture size
Old 1/21/11, 5:04 PM
Robert Ernst Robert Ernst is online now
I agree with Larry that the cracks in the post should pose no problem. It normal to see that when wood dries. The post is inside where it's not going to get any water in the checks.
Old 1/21/11, 5:12 PM
Jeffrey R. Jonas's Avatar
I agree with Larry and Robert on the condition of the posts.
Old 1/21/11, 5:38 PM
Bob Elliott's Avatar
Strange post location in the garage.
Old 1/21/11, 5:41 PM
Stephen W. Stanczyk's Avatar
Regional thing. I see them all the time up here in WA.
Stephen Stanczyk
Old 1/21/11, 5:47 PM
Might be worth it to see if the beam can be supported with a work around eliminating that post.
Would not be hard to back up into.
Old 1/21/11, 5:54 PM
Usually the garages are a little wider than normal (maybe 25-30 feet wide not the normal 20-22) and the beam is right between the two parking spots. I have seen them spanned with metal beams and even the majority of those have a support post.
Stephen Stanczyk
Old 1/21/11, 6:04 PM
That is what I was going to suggest.
Bet the beam is wood.
Old 1/21/11, 6:24 PM
Thank you for everyone's input and advise
Old 1/26/11, 6:40 PM
Duct tape it and it will be fine.
Old 1/26/11, 6:50 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
The duct tape will prevent scratches on the car's bumper.
774 Manor Road
Staten Island, NY 10314
718-514-3393
INACHI Technical Library bkelly2 Miscellaneous Discussion for Inspectors 16 6/18/10 10:45 PM
Structural Links Page mcyr Structural Inspections 52 8/1/09 10:54 PM
Mold Resistant Wood by FrameGuard mcyr General Inspection Discussion 15 1/16/09 9:14 AM
The Rise and Fall of CCA Wood Preservatives mcyr General Inspection Discussion 3 5/4/08 11:19 AM
Preventing Moisture related Problems mcyr Ancillary Inspection Services & Additional Topics 1 12/19/07 8:30 AM
