Old 10/5/09, 9:40 PM
Dean A. Conrad Dean A. Conrad is offline
Default Cracked
Recently I inspected a detached two-car cinderblock garage that had two wide cracks than ran from roof to foundation on opposite sides near the area where the ridge beam was supported. The cracks were slightly wider at the bottom. The cracks went through the blocks, so that light was visible through the cracks. These were not step cracks, but traveled staight down, cracking through the center of some blocks.
I have attached photos, but they are not very good. There was a large amount of junk in the garage, and the structure in question was flanked closely by other garages, so a good angle/shot was not available.
Any idea what caused this?
Thanks for your help.
Dean Conrad
Find an InterNACHI certified Tennessee Home Inspector (and anywhere else in North America)
Old 10/6/09, 1:44 AM
Default Re: Cracked
If the cracks were wider at the bottom and are near a load bearing point (I-Beam), good chance the load up top could be too heavy and possibly affecting the footing. Are CMU's supposed to be filled where they are supporting a greater load?
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 10/6/09, 1:52 AM
Paul Pendley Paul Pendley is offline
Default Re: Cracked
Cant give an opinion from CA as the bricks are usually a veneer covering and not structural in nature.
Paul Pendley
Premier Property Inspections
866-458-8516
Cracked wall / slab foundation question hmiles Interior Inspections 4 9/2/09 12:17 PM
Cracked flue tile bknowlton Inspecting HVAC Systems 6 2/2/07 12:37 AM
Cracked Heat Exchanger jallingham Inspecting HVAC Systems 26 5/11/06 11:12 PM
