Please look at these photos and tell me what you think.
The veneer has 3/4 cracks the support over patio has twisted some, and the door frame or brick molding has pulled at top right side. Personally I feel this is a design flaw and the door opening was not supported properly. Please note the roof above and it's valley. Could this be too much weight for this opening? Thanks, Frank Magdefrau Certified Master Inspector DeSoto Home Inspection Services, LLC 3152 Big Ben S Hernando, MS 38632 (901) 486-0421 InterNACHI Member since 2002 InterNACHI message board member since 2003 InterNACHI ESOP member from 2004 to 2010 |
Did the door shut properly or did it rub against the top of the frame?
What type of foundation was the house on? Was it a basement, Crawl or slab? Is it possible the foundation (to the left of the door) could have dropped a llittle due to the lack of gutters and the large area of roof? I'm just trying to visualize how that step crack could have happened. Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
The home is 2 years old, the door open and closed fine and I did not notice any interior issues other than general cracks in the slab to the right of door. The framing was rafters built on site.
Looks like a problem to me. There is a lot of load on the beam from the roof and dormer loads, and it lands on the door header. It looks like either the door header is not strong enough or is not supported well enough, or the foundation to the left of the door has settled. I would call for an evaluation by a structural engineer.
in my region many patio/garage slabs are poured separate or even at a different time from the house slab and less attention is placed on proper footings at these locations
absence of proper drainage and control expansion joints is also problematic i'd refer to an engineer also and let them be the judge of "design flaw" although we may agree i wouldn't report as such i would advise installation of proper gutter system... ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
I agree with Barry and Jeffrey W. It appears that the area to the left of the door might possibly have settled a minor amount. The crack to the upper left of the door, and pulling away from the upper right, would suggest this. Can't tell from the photos but I would also look for a slight compression of the joint at the bottom right of the door frame. Look to see if that gap, at the top right of the door, narrows as it reaches the bottom of the frame. It would only take 1/2" of settlement of the left side to see results such as these.
As Barry said we do see quite a bit of these issues here with our expansive soils. I also agree that unless I am a licensed PE I would refrain from making a call on design. Many of our issues here are as much, if not potentially more, a matter of improper owner soils moisture maintenance, and grade maintenance, than design. Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
You can only determine ongoing movement over a longer period of time; if the rest of the slab support is good, one could assume that any settling here would be minor, especially if the slab edge in this area had not been excavated after the initial pour for services, etc. |
From the newbie. It looks like, in pic #1, that the brick lentil is only sitting on about half of half a brick and the grout has compressed to almost nil. Had the lentil ran over to the next brick it would have had better support. I'm thinking lintels need to go at least 6 to 8 inches past the brick edge not just the two or so we see.
George |
Mr. Russell is close. It looks to me like the load at the end of that beam caused the settlement. I don't think the lintel had anything to do with it, although I agree with Mr. Russell that lintels should bear on 6 and preferably 8 inches of brick on either side of the opening. Could they possibly have done something silly like rest the end of that beam on only the brick veneer?
That's partially what I was thinking. I'll also bet a dime to a donut that the lintel isn't bolted to the header properly either.
I'm Just George but thanks for the show of respect. |
Brick veneer is just that....a veneer and in this case is not even a "structural" part of the home. It does not support anything. It is virtually a type of siding. This looks like a typical settlement issue due to poorly installed / prepped brick veneer and is fairly common around the upper corners of doors and windows and other openings. Could be caused by a variety of things; little or few or no brick ties at the location to help support the brick veneer and the "soldier course" of brick along the top of wall. The location being under a valley would concern me more about water intrusion through the brick into the wall cavity. Where there any signs of moisture damage to the drywall inside the garage at the location. What we typically seen done for these is a mason come out and examine and / or seal up the cracks to prevent water and vermin from entering. We see a lot of settlement of veneer at corners as well where the brick ledge at the base was poorly finished. If you have ever been on the job site, the brick masons would rather take a bullet than pick up a hammer and nail a few extra brick ties onto the frame so the wall is tied together. sufficiently. They will tell you in a second that is the framing carpenters' job.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
So I've been think about this one and as an old framer I'll guess they tied the beam in with a joist hanger instead of a beam pocket framed into the wall and the lazy helper didn't put enough nails, or they didn't catch, into the hanger. Couple that with the crappy lintel and just maybe.....
George |
| something else to chew on | john bubber | Structural Inspections | 706 | 4/25/12 7:13 AM |
| VIDEO--Bowed Basement Wall, Cracks etc | john bubber | Structural Inspections | 75 | 7/21/08 5:25 PM |
| Long Hairline cracks in a gypsum lath ceiling | rkie | Interior Inspections | 5 | 5/17/08 4:27 PM |
| This from another Home Inspector site | john bubber | Structural Inspections | 4 | 12/9/07 8:17 AM |
| Radon mitigation & sump | dmacy | Plumbing Inspections | 11 | 8/20/06 9:51 PM |
