Old 3/15/07, 9:11 PM
David C. Macy's Avatar
Default Cracks at garage floor & walls
The garage floor was separated form the garage slab foundation. Also at the corner of the exterior foundation there was cracking & displacement about 1 inch. This was the corner next to the garage. There was an hatch area but it was blocked due to the deck. There were no indications of structural problems in the basement.
That is the garage service door in the picture. The extension cord is going across the hinged acess. Seemed like an odd place for an acess. I thought the cracking may be related between the garage floor and exterior. There where also cracks at the same corner in the drywall. I called to have someone open up the access and evaluate.
Any thoughts on the cracking?
ID:	10047   cracks-garage-floor-and-walls-93507-013-small-.jpg.jpg
ID:	10048   cracks-garage-floor-and-walls-93507-012-small-.jpg.jpg
Old 3/16/07, 1:08 AM
jkormos's Avatar
jkormos jkormos is offline
Default Re: Cracks at garage floor & walls
Was the cracking only in this corner of tha garage, was the floor level? Is it a block foundation or poured concrete, was the concrete cracked under the rug by the other door, were the door jambs still plumb
Joe Kormos
A-1st Look Home Inspectors Inc.
630-201-0933
Your 1st Choice in Property Inspection Professionals
www.a-1stlookhomeinspectors.com
www.a-1stlook.com
Let us look before you buy...for peace of mind
“Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford
Old 3/16/07, 4:12 AM
Russel Ray's Avatar
In your area of Ohio, you might have a floating slab that would result in those types of "cracks." Since they're in the garage, they don't cause me a structural concern since the garage foundation is (should be) poured separately from the rest of the house.
Old 3/16/07, 7:13 AM
Charles R. N. Crooker's Avatar
Charles R. N. Crooker Charles R. N. Crooker is offline
RR you seem to be repeating yourself!!!!!
Chuck Crooker I.M.M., Canadian Home Inspectorhttp://www.crookerhancox.com "Not just an inspection, an Education!!!"
Old 3/16/07, 10:32 AM
scosta's Avatar
scosta scosta is offline
Please Note: scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
Dave,
Looks like older work, they should have put expansion joints all the way around that garage floor.
Steve
Old 3/16/07, 5:18 PM
jbreazeale jbreazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
The cracks in the wall raise a red flag. You made the right recommendation.
BTW...is that doggie poo on the garage floor? Call it out as a sanitary issue!!
Bedroom Door leading to garage jberthiaume Interior Inspections 31 6/23/10 6:57 PM
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 6:45 PM
slab no cracks: Brick veneer cracks gkoehl Structural Inspections 1 4/17/07 4:52 PM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 10:48 AM
