Old 4/11/13, 6:59 PM
Mark Kodikan Mark Kodikan is offline
Please Note: Mark Kodikan is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Cracks in Poured Foundation
Hello,
I recently had a home inspection and these cracks were found in the foundation. Inspector said they are shrinkage and no big deal. I want to be 100% sure before purchase. Anyone have any thoughts?
Thanks
Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/11/13, 8:58 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Default Re: Cracks in Poured Foundation
Looks like it, but can't determine without the complete whole picture.
The whole picture is seen by the Home Inspector on site.
Why do you doubt your Home Inspector?
Cyr Home & Commercial Property Inspections
Inachi Award Winner 2009
Old 4/11/13, 9:11 PM
Its not that I doubt him, just looking for a 2nd opinion... Dont want to get burned later on.
Thanks
Old 4/11/13, 11:28 PM
Cameron Anderson's Avatar
Cameron Anderson Cameron Anderson is offline
Seal em and watch em. If significant movement occurs(1/8-1/4") rapidly then you can get concerned.
Cameron Anderson
Integrity Home Inspection
Truth. In Real Estate.
Since 2004
Bachelor of Architecture, U of I, Urbana IL
Illinois Licensed Inspector
www.aaintegrityhomeinspection.com
www.homeinspectionpeoria.com/[/B][/COLOR]
Old 4/11/13, 11:37 PM
David Garton's Avatar
David Garton David Garton is offline
From what I see from the photos I would have to agree with your inspector, also what post #2 says.
"If you work just for money, you'll never make it, but if you love what you're doing and you always put the customer first, success will be yours."
Ray Kroc
Old 4/12/13, 4:51 AM
john bubber's Avatar
john bubber john bubber is offline
Unmoderated Guest
Please Note: john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
Look to be a little wider than shrinkage cracks to my dumb az.
How old is duh home?
Are they in same-wall, 2 or 3 walls?
What city/area you in?
I'd have 'em waterproofed (outside!)
Old 4/12/13, 11:04 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
I wouldn't call them "shrinkage," but more likely settlement. If the foundation is properly reinforced (which cannot be determined by a home inspection) there's really nothing to be concerned with.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/12/13, 3:07 PM
James L. Keilson, CMI's Avatar
James L. Keilson, CMI James L. Keilson, CMI is offline
Send a message via ICQ to jkeilson
Agreed. I would seal them properly to keep moisture and insects out, and not give it much more thought. IF you really are concerned you can always have them evaluated by a qualified engineer. I personally wouldn't but it is your call.
Jim
"We Respect Our Clients Right To Privacy"
Jim Keilson Certified Master Inspector
MarylandHomeInspectionServices.com
www.MarylandRadonTesting.org
State of Maryland License# 31141
Virginia Certification#3380 000468
InterNACHI ID: NACHI10101807
(IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Old 4/12/13, 6:43 PM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
Take a level to all four corners of the home (top of foundation and floor). If level good. Next take the level and walk horizontal down the walls to see if they are straight. If level good. Best way to do this however is with what's called a plumb bob. If your corners are not level footing may have dropped. If everything is straight/level seal the cracks to prevent moisture and monitor for movement until you see width (1/8-1/4") like said above. If the home is old most likely most of the settlement is close to being done. If the home is pretty new get a second opinion by a foundation contractor. If you're really worried call in a foundation guy with a laser level. Most will come out for free to give you an idea/bid. Some won't until you're already the owner. Did the inspector report any wall cracks inside or out? Also take a look at your roof is the ridge line nice and straight? Is the rest of the roof nice and staight. Sag/dip/humps/waving you need to have someone come out.
http://www.askthebuilder.com/house-f...ions-footings/
Old 4/13/13, 9:14 AM
Waqar Quraishi's Avatar
Waqar Quraishi Waqar Quraishi is offline
Worth repeating.
The answer to the above would be suited to minimize your concerns.
Good
questions John.
WARNING: I'm not responsible for the opinions expressed herewith. Apparently my pets have learned how to press keys.
Old 4/14/13, 12:59 AM
Nothing about your pictures look uncommon
Old 4/14/13, 3:05 AM
Gary Farnsworth, CMI's Avatar
Gary Farnsworth, CMI Gary Farnsworth, CMI is offline
Typical. Seal'em, monitor them.
Termite #16601 KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 4/14/13, 10:16 AM
This appears to be a vertical tension crack caused by local soil subsidence causing
downward displacement of exterior foundation. Read post #6 above.
Old 4/14/13, 12:07 PM
Unmoderated Guest
Most of the vertical cracks we see is due-to lateral soil pressure against duh wall, as U S Army Corps says/shows here on page 35, photo 6....
http://www.amherst.ny.us/pdf/buildin...S_section3.pdf
'Lateral pressure causing vertical fracture.......'
Vertical crack in poured wall
http://picasaweb.google.com/10104903...30319512131138
Renovating Your Basement for Livability mkyriacou Canadian Inspectors 0 10/22/09 12:45 PM
Foundation wall cracks and bowing jmanders Structural Inspections 8 5/27/09 10:03 PM
Cold weather poured foundation Mark Soden Structural Inspections 14 5/22/09 9:54 PM
Dampness in basement- new construction jcundiff General Inspection Discussion 47 6/21/08 12:35 PM
Common Defects List by Age of House trausch Inspection Education & Training 10 6/12/06 5:52 AM
