Per the ICC code check book..It says that the
access opening must be 18in tall by 24 in. width for entrance. What about the distance from the ground to the floor joist? Some of you know about my issue with a customer complaint. A plumbing leak a customer says I missed. I went back and re-inspected. I measured the access opening it was smaller the 18 by 24. Also their was only 12 inches from the ground' to floor joist. What is the safe distance for going across a crawl space?. I did not go across the crawl space because it was only 12 inches high. David |
| Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
What did you tell them at the time of inspection about the crawl? While the $800 may seem high, I could see a plumber quoting that to work in a 12" high crawl space. ***Members only may be a better place for this thread, IMO*** |
David, other than the minimum that you quoted it may need to be larger to service any equipment under there such as water heater, furnace, etc......so dont get caught up on a minimum.
As to the elevation height, code is 18 inches for joist and 12 inches for girders.....which is all but impossible to crawl under; in such cases there should be additional access doors to ensure that all areas are accessible. Whenever you do not inspect a system or component, for whatever reason, you need to annotate same along with the reason it was not inspected. All crawls should have a positive drainage system (located at the lowest section of the crawl) to ensure any built up moisture is properly drained out of the crawl. Hope this helps Jeff PS. When you went back to do a reinspect, what was the source and cause of the leak? |
[quote=rmaday;642080]What did your PIA and report say about the crawl?
What did you tell them at the time of inspection about the crawl? While the $800 may seem high, I could see a plumber quoting that to work in a 12" high crawl space. My reply: I did not note on the initial report ...that the access was smaller than 18 by 24. The $800 dollars actually was a quote about drying the basement...We settled for $150. I think I could have won in court. On re-inspection I seen that this leak was hidden. No way for to me see it on the day of Inspection without any visible clues. The house only had one crawl space entrance !!! opposite of the kitchen and only 12 inches high !!!. On the reinspection I brought a flood light....you could not see the plumbing break all the way across the house. No signs of wet dirt from the access. If I had written the limitations in the report it would have been a non issue. Im taking it as lesson learned for future crawl space inspections where I cannot see all the plumbing. And advise the customer to seek a license plumbing contractor for an expert analysis for possible hidden plumbing issues. David |
[quote=dnasser;642087]
Like others have said it's important to note the limited access in the report. Even better if you can provide photographs of the limited access. That way when you get the call about ( ) you have documented proof that the area was not accessible. To the buyers was right for calling you on it because you didn't indicate in the report the access was limited. As far as they are concerned you failed to inspect and report. I find it's more than worth it to make an extra effort to crawl all the way to the end even it's it dirty and a long way. If you hit a low spot look for a high spot and go around. If there's just no way then take a photograph and note it in the report. Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified Last edited by vsantos; 4/4/10 at 3:33 PM.. Reason: beer |
Utilizing OSHA's own rules and logic for requiring special provisions when it comes specifically to confined spaces, and seeing how a crawlspave is indeed a confined space, I would have brought up the OSHA guidelines. It is unreasonable, IMO, to call an inspector out for failing to enter an 18" high space. Take the Safety Course and see what may await. A bite from a brown recluse is all it would take. |
Just note it , explain it. I agree with Jeff.
Remember you win some and others just use it as a learning Opportunity . I am sure everyone here has a least one bite in the butt lol Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
Man that sucks, but like others have posted it's a learning opportunity.
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
If the crawl space has limited clearance anywhere, the buyer should be told about it and forewarned about the potential negative consequences of owning a home with a low crawl space. You need to do more than simply say "I couldn't get in to this area and defects may exist that were not identified".
Personally, I'd back out of buying a home that had limited access in the crawl space due to the problems associated with ventilation, routine entry, inspection, and maintenance. Those limitations should be clearly identified in any report. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 4/5/10 at 8:21 AM.. |
www.MauiHomeInspections.com |
He does not have to go in there, but...
...it should have been spelled out in the report. Quote:
If I were down there in poisonous snake and spider country, I'd probably use that phrase a bit. Most houses have full depth basements here; the odd crawlspace I have to get into up here is bad enough with worrying about poisonous creatures!!
Thanks...this info sure does...
[quote=vsantos;642213]
| Alkali and efflouresence in crawl space | lgerving | Structural Inspections | 0 | 2/12/07 11:13 AM |
| No Crawl Space Ventilation | dmccormick | Structural Inspections | 11 | 2/5/07 10:34 AM |
| Is Romex in a crawl space a problem? | jtedesco1 | Electrical Inspections | 48 | 9/30/06 10:53 PM |
| Crawl Space Drainage | brooke949 | Structural Inspections | 6 | 8/29/06 1:42 PM |
| Strange Duct in Crawl Space | jfunderburk | Structural Inspections | 3 | 1/11/06 12:02 AM |
