Go Back   InterNACHI Message Board > Specific Inspection Topics > Structural
Structural Contains discussions about the structural portion of a home inspection. This includes foundations, framing, et cetera.
Old 2/24/07, 12:22 AM
David Nasser David Nasser is offline
Default Crawl space in under house
Im in California, our code book says the crawl space opening
must be 18" high by 24" wide for entry. Does the crawl space have
maintain the 18" height for me to keep inspecting crawl space area ?
The house that I inspected had a 18 by 24 opening but did not
maintain 18 height on the concrete pier foundations.
David
Pyramid-Home-Inspections
Old 2/24/07, 3:00 AM
sspradling sspradling is offline
Please Note: sspradling is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Crawl space in under house
David,
As a general rule, if I can belly crawl my self through, I go. That's why I keep coveralls and and a respirator mask, and extra flashlights, and etc., etc. in my vehicle
First thing I want to do is see all that is "accesable" The last thing I want to do is get stuck. By the way, as HIs we don't inspect or quote code.
Stu
Old 2/24/07, 11:26 AM
Joe Funderburk, CMI's Avatar
My state's SOP says I don't have to inspect a crawl < 18". Be aware of today's standards for minimum distances between soil and untreated lumber and put that in your report if it isn't met.
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 2/24/07, 11:29 AM
thanks
Old 2/24/07, 11:43 AM
David P. Valley's Avatar
David P. Valley David P. Valley is online now
If you've got a gut, forgidaboudit.
Old 2/24/07, 12:37 PM
Jeffrey R. Pope's Avatar
My general rule of thumb is that if I can fit without removing my respirator, it gets inspected.
The vast majority of modern CA homes are built on slabs - unless, of course, they're a hillside home. Most crawl spaces in CA date back to the mid '60's and earlier. That's many years of pesticide build-up, not to mention the potential for asbestos building materials.
I don't sacrifice my PPE for anything. . .
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/24/07, 1:53 PM
William E. Siegel William E. Siegel is offline
Jeff just made a really important point. I hope all of you are wearing your masks / reapirators when you go under these units. There can be some pretty dangerous chemicals under there.
Old 2/26/07, 10:21 AM
Steven Taylor's Avatar
Steven Taylor Steven Taylor is offline
Dosen't OSHA state that a crawlspace must be 4'?
Old 2/26/07, 10:31 AM
OSHA regulates "employee" safety. Not owner safety. It doesn't give a hoot about residential constructions standards. And OSHA doesn't "approve" ladders or anything else.
Joe Funderburk, CMI
Old 2/26/07, 11:13 AM
David Valley, you crack me up. You get the greatest photos.
Stu
Old 2/26/07, 3:23 PM
David E. Helm's Avatar
David E. Helm David E. Helm is offline
Been stuck a few times. It can be scary, but not as scary as missing WDO issues.
Helm Home Inspection
David Helm, Owner/Inspector
http//www.helmhomeinspections.com
Old 2/26/07, 3:56 PM
Robert J. OConnor's Avatar
The following is from the IRC as a guide ...
R408.3 Access (for "Under-Floor Space")
Access shall be provided to all under-floor spaces. Access openings through the floor shall be a minimum of 18 inches by 24 inches (457 mm x 610 mm). Openings through a perimeter wall shall be 16 inches by 24 inches (407 mm x 610 mm). When any portion of the through wall access is below grade, an areaway of not less than 16 inches by 24 inches shall be provided. The bottom of the areaway shall be below the threshold of the access opening. Through wall access openings shall not be located under a door to the residence. See M1305.1.4 for access requirements where mechanical equipment is located under floors.
Therefore, I look for 16" of clearance from grade to framing as a minimum to enter a crawl space.
But if you don't go in you better clearly flag you didn't fully inspect the crawl space and the potential for defects, as it's usually a common problem area ... and perhaps even recommend they budget for addressing common crawl space issues until it can be fully inspected.
JMO & 2-nickels ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/rjo
Old 2/27/07, 7:09 AM
Does OSHA apply if you have an inspector working for you?
Old 2/27/07, 10:25 AM
Yes. Then your company would be regulated. (The employees would be regulated--not the owner.) They have no rules that establish when a crawl space height is considered safe. However, OSHA does have a General Duty Clause. It covers areas of occupational safety and health that are not addressed by a specific standard. It states that the workplace "must be free from recognized hazards that are likely to cause death or serious physical harm." One of the things OSHA would be looking at, if anyone were to get injured or killed, is: employee training, and policies and procedures.
So, if you have employees it may well be good to establish procedures such as "if you have to remove your respirator, do not proceed" or "under no circumstances enter a crawl space < xx inches". "Do not cross electric lines that are on the ground", etc. You should document that instruction at least annually, with employees signing a training form. You also need to establish disciplinary action procedures. Training is worth nothing if it isn't enforced. You can't cite employee misconduct if you never enforce your rules.
I was an OSHA Compliance Officer in SC for 4 years. I conducted many fatality investigations. Let me know if you have other questions.
Joe Funderburk, CMI
Old 2/27/07, 11:40 AM
If I can fit I get in there, with one caveat. I must be able to turn around to get the heck out. We have too many critters in all seasons of the year that love to nest in a crawl space, or under a manufactured home, and since Dave Valley found a picture of me, you can see I need considerable space to turn around.
If the opposite of pro is con, the opposite of progress must be...
Crawl space venting? prussell Exterior 56 11/19/07 6:48 AM
Reporting on mold in crawl space rtruluck Structural 9 8/30/07 12:31 AM
Crawl Space Info jmckenna1 Misc. Discussion 1 7/6/07 10:07 AM
Age of Bard furnace in crawl space abishop HVAC 3 6/29/06 10:13 AM
Vegetation Grwoing in Crawl Space carolinainspector Structural 3 6/23/06 6:28 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
