On A new home should faced insulation be used in the crawlpspace between the floor joist. On the floor above there is hardwood flooring goind down with no underlayment or vapor barrier. Is this a sign of futre vapor issues?
J.Szczesny 4 Seasons Home Inspections Washington State Inspector # 711 800 5th Ave #101-385 Seattle, Wa 98104 (206)391-0285 online @ www.4seasonsinspects.com email @ info@4seasonsinspects.com toll free cal @ 866-512-9972 "For the best protection, get the right inspection" |
| Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
This graphic may help....
Looks like an OSB subfloor to me. Am I misunderstanding what you're saying?
James,
The faced side should be toward the floor area. Also it is best to put a 6 mil poly throughout the crawlspace. If it is a nailed down floor then that installer should have put at least a #15 felt under the hardwood. With crawlspaces wood flooring has a tendency to cup, especially with larger boards. Jeff |
dquigley is a non-member guest and is in no way affiliated with InterNACHI or its members.
In Florida this scenario is often a dissaster. Vapor barriers and insulation are needed. The direction that the vapor barrier faces is probably flip flop in your neck of the woods from what would be done in Florida, so I will leave that to others to answer. In Florida we have excessive heat and humidity on the exterior and cool dry air on the interior. We are trying to keep the heat and humidity from reaching the flooring. I have seen many floors cup and warp due to the crawl space, and have even had to include special addendums to my construction contract to account for them.
| Holmes Inspection | dcolangelo | Canadian Inspectors | 20 | 3/12/10 5:57 PM |
| Will missing vapor barrier & unvented crawlspace make Radon levels elevated ? | tchristopher | Ancillary Inspection Services & Additional Topics | 24 | 2/22/09 10:39 PM |
| ? possible reasons for crawlspace mitigation | jeubank | General Inspection Discussion | 11 | 2/17/09 4:57 PM |
