Old 10/31/06, 5:44 PM
kweiss's Avatar
kweiss kweiss is offline
Default Creative Handrail
Can anyone guess the material used to make this handrail.
Needless to say, I doubt it will hold up a falling person and noted such on the report.
Kevin Weiss
Professional Inspector
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Old 10/31/06, 6:09 PM
arook arook is offline
Please Note: arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Creative Handrail
PVC.
Also, needs properly spaced vertical spindles.
Andrew Rook
Rook Home Inspections LLC
www.rookinspections.com
Old 10/31/06, 6:11 PM
Jeffrey R. Pope's Avatar
Those steps don't require a rail to begin with, so step lightly (no pun intended) with your recommendation. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/31/06, 8:33 PM
wsiegel wsiegel is offline
maybe it was installed to help an older person. If so, they should secure it better.
Old 10/31/06, 8:41 PM
Peter C. Russell's Avatar
That looks like 1 1/2 pvc pipe, it should be 2 1/4 ha ha
Old 10/31/06, 10:00 PM
Looks like 3 risers to me which makes me recommend that a railing with properly installed spindles be installed for safety.
How many risers do you look for?
Does the height of the steps look off as well (too small), or is it just the picture?
Andrew Rook
Old 10/31/06, 10:30 PM
Roy D. Cooke, Sr's Avatar
I do think there should be a landing at there so you do not open the door and fall down the steps . Roy Cooke
Old 10/31/06, 11:01 PM
From the 2003 IRC R311.5.6 Handrails. Handrails shall be provided on at least one side of each continuous run of treads or flight with four or more risers.
Old 11/1/06, 1:23 AM
What standard would you base this recommendation on?
I agree, that if it's in place, it should perform its intended function, and conform to the standard requirements of a railing.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 11/1/06, 1:52 AM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Roy
Our code 9.8.4.2 [1] [2] [3] [4]
You are correct if this is the main door of dwelling,however if this is a secondary entrance [side door] then the answer is no.
And Jeff is correct,hand rail not needed,however if one is installed it should be secure.
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 11/1/06, 2:23 AM
wforsyth's Avatar
wforsyth wforsyth is offline
Please Note: wforsyth is a non-member guest and is in no way affiliated with InterNACHI or its members.
It looks to me like the tread is sloping and not level. They look like the first set of amateur steps my husband did. The kind where you fall forward when you start to go down them because they slope.
Old 11/1/06, 9:30 AM
Wendy
Sloping? Maybe it's the angle of the shot.
Tel.# 416-722-6132
Old 11/1/06, 10:02 AM
wforsyth's Avatar
Maybe it is. If I blew it up I could probably tell more.
Old 11/1/06, 10:18 AM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
From my own past experiance, I would call it out as requireing a proper handrail for any steps with more than 2 risers. The city of Mt. Clemens would not let me close on my first house because I had to pass their city certs.
I had to leave the closing & install a handrail on the steps, (2 6" tall steps & 1 3" tall step) have it inspected and then rush back to finish the closing. I was buying my grandmothers house.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 11/1/06, 10:28 AM
Jeff,
I forget that every state is not like NJ. In NJ, we follow New Jersey's version of the 2000 edition of the Internation Building Code (IBC/2000) and therefore, it's not 4 risers, it's 3 risers.
IMO, in situations like these it never hurts to recommend that a properly installed railing with balusters be installed for safety. Either way, I agree with you that if it's there, it should be done right.
Andrew Rook
Be Smart, Be Sure, Be Inspected TM
Creative Plumbing Solution pdickerson Plumbing Inspections 3 9/29/07 3:36 PM
Continuous handrail where winders used for landing kshepard Interior Inspections 3 7/30/07 5:45 PM
Handrail? nbhi Structural Inspections 6 6/25/07 2:30 AM
Now this is creative! jweinberg Electrical Inspections 5 5/11/06 10:11 PM
