jweinberg is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are wood structural panels required on the inside of cripple walls of a 33 year old home with 2x6 vertical studs if there is already wood sidiing over plywood sheathing on the exterior of the wall?
What if it only had 2x4 vertical studs? |
Jeff,
Cripple walls do not require a wall covering on the inside, as long as there is no insulation installed with the vapor retarder exposed. Then a wall covering wiil be needed to cover the combustible vapor retarder. |
| CMI imposter? | jbraun | Certified Master Inspector (CMI) Discussion | 118 | 11/26/07 5:55 PM |
| Best way to insulate basement walls? | Bill Featherstone | Interior Inspections | 13 | 11/4/07 12:34 PM |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 7:45 PM |
| supply in slab or walls? | jeubank | Plumbing Inspections | 1 | 7/8/06 11:36 AM |
