Old 1/21/12, 6:06 PM
Joe Fleet Joe Fleet is offline
Default PEX fireblocking
Can someone refresh my memory on the fireblocking requirements for a PEX manifold installed at a common wall with the garage?
thanks.
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/21/12, 6:33 PM
Default Re: PEX fireblocking
Tested in accordance with ASTM E814, UL1479 UL Classified 1 and 2 hour rating
http://cableorganizer.com/abesco-fir...aulk-cp310.htm
Old 1/21/12, 6:49 PM
Barry Adair's Avatar
http://www.houseneeds.com/shop/manua...ock_manual.pdf
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 1/21/12, 6:59 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
You should also explain what the fireblocking does.
It will not stop a fire when the pex melts but prevent fumes passing through the chase. This is required to prevent flame and hot gases to the other side of the wall. If the pex goes through the wall of the garage you would have to consider the melting point of the pex.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/21/12, 7:34 PM
Kevin, that meets the fire rating required for residential.
Old 1/21/12, 7:47 PM
Wayne B. Wilson's Avatar
Thanks Marcel and Barry good info
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 1/21/12, 7:56 PM
KEVIN WOOD's Avatar
Marcel I know! I am talking about the pex through the wall. If you group the pex no matter what you do with fireblocking it will not work. One line no problem multiple lines not recommended. Again this is according to the AHJ.
Since he has pointed out a manifold. How many holes do you think he has through the garage wall?
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/21/12, 8:16 PM
The best you are going to see in a residential setting is what I posted.
At the very best, a metal sleeve might be incorporated by a contractor that knows what he is doing.
There are sophisticated fireproofing products out there for all situations, but you will rarely see them in residential.
Further more, most walls in a residential unit are not rated for 1 hour.
They only need to be a fire separation and smoke and flame barrier.
Fiberglass wool would meet that criteria.
Old 1/21/12, 8:43 PM
KEVIN WOOD's Avatar
Agreed and not are call. According to Uponor
Fire-Resistance Contruction Standards
Note: Uponors 3/4 through 2 inch meets ASTM E84 covered with 1/2 inch fiberglass insulation, Three pipes are allowed in one spot and any additional would need to be 18 inches apart. There should be no exposed tubing.
If they are closer than 18 inches only they will need extra protection.
Larger penetrations may not use firestop.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/21/12, 9:55 PM
Christopher Currins's Avatar
Then you'd have a sprinkler system.
Christopher Currins
Certified, Licensed
Old 1/21/12, 10:18 PM
KEVIN WOOD's Avatar
YEP! I thought of that too Christopher.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/21/12, 11:31 PM
Tim Spargo's Avatar
Anyone ever see a fire barrier / collar used on Pex?
Tim Spargo
Spec Rite Inspections
661-317-5770
Balloon Frame Inspection belliott Structural Inspections 13 4/4/08 8:27 AM
Fire bloking jlybolt Inspecting HVAC Systems 2 5/7/06 11:45 PM
