Old 12/10/08, 1:11 PM
Stan Croenne Stan Croenne is offline
Default Crown in floor
Got a call today from a client I did an inspection for in July saying she had a crown in her living room floor that had never been there. I went over and sure enough there is a small crown in the middle of her floor. I went into the crawlspace to see If I could determine the cause. Everything in the crowned area looked fine from the crawl. Foundation, floor joists, sub flooring was tight to the floor joists. I did notice that she had not closed her vents for the winter. Could the cold air in the crawlspace cause the floor joists to lift up simular to truss uplift in attics? I have never seen this before. I would appriciate any feed back. Has anyone ran acrossed this in the past? Thanks, Stan
Old 12/10/08, 2:44 PM
jkogel jkogel is offline
Default Re: Crown in floor
Is it hardwood or laminate flooring? Floating floors can swell and do that, caused by not enough expansion room at the walls. Doesn't mean the subfloor is moving. If it's carpet flooring, I don't have a clue.
John Kogel
www.allsafehome.ca
Old 12/10/08, 5:15 PM
Living room is carpeted.
Old 12/10/08, 11:01 PM
Bruce A. King's Avatar
Thats called a "raised joist"
It usually occurs in a new home when a 2x joist drys out and gets a "crook".
A bow would be sideways, a crooked board would go up or down usually more in the center of the joist.
Its always possible that the joists on either side went down and left this one at its normal position which would then look higher.
No way to blame it on the venting, its just one of the characteristics of lumber that shows up sometimes.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 12/13/08, 12:51 PM
Barry Adair's Avatar
Wood warps, fact of nature, if the crown is severe enough relief cutting and sistering may be a course of action. This would have to be an approved design as I'm not there to tell if this would be a feasible or practical fix, but I've done this successfully.
hth
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/14/08, 5:07 PM
1. What types of joists were used- conventional or engineered? Engineered joists move very little and conventional joists might lose 1/4" in width as they dry but seldom bow or twist once installed.
2. Do they lap on a structural beam down the center or span the entire floor? If they lap, settling perimeter foundation or heaving posts under a beam may be the cause.
3. Was there any give apparent when you bounced on it or was it solid? In other workds, is the framing bowing or is it the floor-covering material?
4. How old is the home. Many home foundations will settle over many years, Especially older homes
5. Any expansive soil in your area?
Was the crown uniform along its long axis?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 12/17/08, 10:01 AM
1- Conventional
2- Yes
3- No
4- 15 years old
5- No
The crown is present in the middle of the room only.
This is there first winter in the home, they are going to see if it goes away when the weather warms up in the spring. Stan
Old 12/17/08, 10:19 AM
The situations in older homes or homes that are not new that I've seen have been caused by foundation settling around the perimeter over time. Soince the floor didn't appear spongy it sounds as though the problem is with the framing, not the floor-covering material.
Typically, since the posts (or post) supporting the center girder on which the joists lap have less exposure to moisture (due to their location in the middle of the crawlspace or basement) the girder maintains its elevation as the perimeter foundation settles to some degree. This creates the crown.
This would be especially suspect if the the girder was two beams which butted each other above a single central post, since the high spot was in the center. Was the high spot directly above a post?
(303) 717-8940
Old 12/22/08, 10:22 AM
No. The crown is approx. half way between the outer foundation wall and the main support beam that runs down the middle of the home.
Old 12/22/08, 10:31 AM
Wayne B. Wilson's Avatar
I have this in my own home every winter It is the flooring i believe In the spring it goes away , my home is 50 so i do not get to excited . i have checked and checked everything looks fine down in the dark depths of my crawl space. I have hardwood
Commercial Electrical Inspections jtedesco1 Commercial Inspections 29 1/12/08 5:03 AM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
